Construction Tips Construction techniques and tips
Stacking multiple laminations of plywood to create speaker enclosure
Old 27th July 2010, 07:56 AM   #1
ChrisR1983 is offline ChrisR1983  United Kingdom
Default Stacking multiple laminations of plywood to create speaker enclosure
Hi All
Does anyone use a technique detailed in this build to create a curved speaker enclosure shape (I'm referring to the 'egg')? Humble Homemade Hifi
I want to investigate this further... anyone know of any interesting threads to read on the subject? I have searched but don't really know what I'm searching for!
Cheers
Chris
Chris R
Old 27th July 2010, 10:37 AM   #2
TTrelease is offline TTrelease  United States
Try here:
18” down-firing EGG shaped sub build… - Page 2 - AVS Forum
Old 27th July 2010, 01:04 PM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
While I have not seen it used in plywood speaker enclosure construction. I have seen the W.E.S.T. (Wet Epoxy Saturation Technique) used to make complex curved plywood items in several other areas.
How to / Publications
Kevin
Old 28th July 2010, 11:48 AM   #4
R.I.P.
A vacuum bag around the shape may help in clamping the sheets together and reducing the air content of the glued interface.
Even half an atmosphere of suction will be a big improvement, but try for 90% atmosphere of suction.
regards Andrew T.
Old 28th July 2010, 01:36 PM   #5
bear is offline bear
expert in tautology
bear's Avatar
For glueing up in this sort of situation (stacked pieces) , a press is what is called for... One might use a hydraulic jack working UP against something like the main beam of your house, for example, or an automobile press (a steel frame with a 20 ton hydraulic jack)... your choice of glue is important too, but not so critical imo.
Or just a lot of bar clamps will do the trick too... yep I'd probably use my bar clamps and some stiff flat bits for spreading the top and bottom pressure...
I'd be glueing it up in steps, not all at once...
That is, if I felt the need to do a project like this...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 28th July 2010, 01:50 PM   #6
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Check some of the boat building sites.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 28th July 2010, 02:03 PM   #7
Studio Au is offline Studio Au  United Kingdom
You could,
a) CNC out the rings, you could even do it in dovetail sections, so in stead of having 15 rings on a board, you would have 60-70 smaller pieces that could slot perfectly together.
b) In my opinion, it would be way way easier to find something pre-made thats suitable (aka my ikea salad bowl speakers) You must be able to find some beautiful chopping boards, or fruit bowls, wire mesh or i have even heard of balloons being inflated and covered in resin or other strong compounds.
I guess you need to know whether you desire the shape, inside &/or out, the material concentric layers of ply looks pretty special, or both. Without the aid of a CNC machine, it will be a long process.
Old 28th July 2010, 02:04 PM   #8
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I used screws all the way through until the front and back pieces where I simply used weights
planet10 needs your help:
Let's help Ruth and Dave
Old 28th July 2010, 04:36 PM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
One of the terms you want to search on is Translam. This technique is becoming fairly popular because it is a relatively easy (but wasteful -- Cal did find a creative & useful way to use his scrap) way of creating complex shapes. Plywood is a good idea, i've seen far too many of the MDF ones slpit right in the middle of a piece of the MDF.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th July 2010, 04:42 PM   #10
Thanks Guys. Cal - I did see your thread; it was a good read.
Any advantages to doing it the "Translam" way? I was going to use a router on the inside of the walls so not to create a uniform wall for internal reflections.
It is pretty wasteful but is there anything good (better) than a traditional box build aside from being able to create shapes more easily?
Chris R
Stacking multiple laminations of plywood to create speaker enclosureHide this!Advertise here!
Undivided Sealed Enclosure Response With Multiple Drivers... HsOffRoad Subwoofers 5 7th October 2007 02:59 PM
Multiple drivers in the same enclosure MJ Dijkstra Multi-Way 4 20th November 2006 10:01 PM
Stacking Amp Inputs Into A Speaker Dominick22 Chip Amps 1 4th May 2006 07:02 AM
Bamboo Plywood for Enclosure pjpoes Multi-Way 24 27th October 2005 08:16 PM
Possible to create a 12cm radius waterproof speaker?? docerido Planars & Exotics 5 6th May 2005 05:18 PM
