Construction Tips Construction techniques and tips
Maths help -Output cap selection
Old 16th July 2010, 01:28 PM   #1
zebra100 is offline zebra100  United Kingdom
Default Maths help -Output cap selection
Can someone please help with the equation at the bottom of the diagram?
I have some headphones with a frequency response of 16Hz to 22kHz and and impedance of 24 ohm's, but no matter how I manipulate the equation, I can't seem to work out the output cap value (C2).
Thankyou.
Chris.
Old 16th July 2010, 02:03 PM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
You don't need to manipulate the equation, just stick in your values. They're assuming an LF cut-off frequency of 10Hz, I'd go a bit lower myself as a 10Hz -3dB point introduces phase distortion below 100Hz.
But assuming you want to follow their equation then C2 (in microfarads) is 1E6/(2*pi*10*24) which my calculator says is 663uF. I'd be inclined to use 2,200uF myself.
<edit> don't forget to heatsink the LM317
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th July 2010, 02:22 PM   #3
R.I.P.
Its just a re-arrangement of R=1/(2piFC) for a 1st order filter.
I do not see why "must" comes into it, 2,200uF will be fine
for any headphones (the min is 8 ohms & any higher value).
/Sreten.
Old 16th July 2010, 02:40 PM   #4
R.I.P.
d.p. delete does not work
Old 16th July 2010, 02:47 PM   #5
Doh!!!!
Thank's, it was giving me a headache. I (stupidly???) assumed that the calculation gave the answer as farad's as opposed to uF's. That's why I couldn't see it.
I'm using 470uF at the moment. Will this be too low, and if so, how will it affect the circuit/sound?
Chris.
Old 16th July 2010, 02:52 PM   #6
abraxalito's Avatar
470uF just means that you'll get more bass roll-off, and I guess that subjectively the bass will sound 'slower' than with 2,200uF. The bigger value I imagine will 'tighten' the bass.
Old 16th July 2010, 03:06 PM   #7
Will this value adversly affect the circuit i.e. extra heat?
Chris.
Old 16th July 2010, 03:08 PM   #8
abraxalito's Avatar
No, can't think of a single adverse effect on the circuit operation.
Old 16th July 2010, 03:25 PM   #9
R.I.P.
Its actually quite the opposite with manipulating bass roll offs.
FWIW 470uF is a fine value for typical walkman type headphones.
They are around 32 ohm, yours are lower than typical but will
still be fine with 470uF. Only if you want 8ohm compatibility
do you need to increase it, to between 1,100uF and 2,200uF.
And FWIW the equation is wrong, it should read C(uF) = ....
/Sreten.
Old 16th July 2010, 03:28 PM   #10
abraxalito's Avatar
So you've listened and found that a smaller cap tightens the bass and a bigger one slows it down? Which 'phones did you hear that with?
Maths help -Output cap selectionHide this!Advertise here!
selection of output power tr arthur Solid State 10 25th September 2009 11:40 AM
6G15 output transformer selection layt Tubes / Valves 0 2nd July 2006 01:55 AM
Input cap selection Deltat Parts 10 12th May 2006 04:54 PM
Irrelevent stuff spilt from Cap selection thread SY Everything Else 120 17th June 2003 03:33 PM
Copyright ©1999-2017 diyAudio
