Modifying 4-band semi-parametric to fully parametric with shelving? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th July 2010, 06:02 PM   #1
Default Modifying 4-band semi-parametric to fully parametric with shelving?
hey all-
I found a schematic for my mixer, but the only problem with it is that it's four bands of peaking, semi-parametric equalization. (schematic shown as an attachment below)
What I would like to do is add bandwidth control (I would prefer bandwidth, but Q control also works for the purpose of the mixer) and also make bands 1 and 4 switchable between shelving or peaking. In peaking mode, the bandwidth knob would be active so I would still have fully-parametric equalization when in peaking mode.
How would one go about modifying the EQ?
thanks,
Mike
P.S. How do I change the frequency range? I know it has something to do with the caps, but what's the formula between farads and frequency range?
Old 4th July 2010, 07:11 PM   #2
Mooly's Avatar
You need to read up on "gyrators" as this is how your equaliser operates. It "synthesizes" an inductor by using opamps instead.
http://cas.web.cern.ch/cas/Denmark-2...%20CAS2010.pdf
Gyrator - Wikipedia, the free encyclopedia
Also this might be of interest, the last part,
Spectrum Analyzer and Equalizer Designs
Installing and using LTspice IV. From beginner to advanced.
Old 4th July 2010, 08:35 PM   #3
the equalizer in that last link sounds perfect except for two things:
-there's still no way to make the first and last bands shelving
-how does one change the upper and lower extremes of the frequency range?
also, would I connect the signal ground from the EQ to the mixer's main signal ground bus?
Old 5th July 2010, 07:38 AM   #4
Mooly's Avatar
The values of R and C in each gyrator determine the frequency of operation. Typical values such as,
10-Band Graphic Equalizer Using Gyrator Circuit Diagram | circuitwiringdiagram.com
"also, would I connect the signal ground from the EQ to the mixer's main signal ground bus?"
Signal grounds are normally connected together paying attention to correct practice... no loops etc and returning critical signal grounds to a common point or star.
Parametric Schematic punchpeanut Parts 11 7th March 2011 01:04 AM
semi parametric eq reap461 Parts 5 4th December 2008 09:56 PM
Analysis on semi parametric eq's Aggression Instruments and Amps 0 2nd October 2008 06:18 PM
Parametric Q Calculation--help, please tocs100 Multi-Way 3 2nd January 2006 01:21 PM
parametric equalizers stupid m0nkey Everything Else 7 16th February 2005 05:49 AM
Copyright 1999-2017 diyAudio
