Construction Tips Construction techniques and tips
LED polarity
LED polarity
Old 21st June 2010, 04:20 PM   #1
jmillerdoc is offline jmillerdoc  United States
jmillerdoc's Avatar
Default LED polarity
I was wondering if anybody knew of a simple way of telling the polarity of an LED by simply looking at it?
Jeff
Old 21st June 2010, 04:27 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
LED polarity
Try this
led polarity - Google Search
planet10 needs your help:
Let's help Ruth and Dave
Old 21st June 2010, 05:08 PM   #3
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Originally Posted by Cal Weldon View Post
Cal Weldon Consulting at it's finest.
If that was a free sample, the paid service must be unbelievable!
Old 1st July 2010, 11:00 AM   #4
gmphadte is offline gmphadte  India
Can u see the pins inside. Is it a non-white LED.
The smaller looking one is positive i.e. anode.
Old 2nd July 2010, 08:42 PM   #5
BrianVG is offline BrianVG  Belgium
The long pin is the positive and the shorter is the negative. If you have a multimeter you can also test it with the mode to test resistance, if a material has a lower resistance than xxxOhm(200 with my decive) it wil 'beep'. So when the LED lights up you can see from you probes wich is positive and negative(COM=negative). The multimeter will send a little current trough the led to test resistance but this will also let you LED work.
Old 3rd July 2010, 07:03 AM   #6
wwenze is offline wwenze  Singapore
May or may not work depending on the band gap voltage of the LED, typically a few volts, vs the voltage from the multimeter, typically in millivolts.
Old 3rd July 2010, 08:33 AM   #7
Mooly's Avatar
LED polarity
Looking at the LED is an old trick... many new ones don't conform nowadays.
It's never a problem, a DVM on diode check lights most to confirm, if it doesn't a 9 volt battery and 10 k resistor does.
And just to go slightly off topic, where it does get really spooky is identifying the drain and source on a common JFET.
I have the "official" answer from the man himself (Bob Pease of National Semiconductor) if anyones interested
Old 3rd July 2010, 08:41 AM   #8
Worked perfectly for my 7-segment displays. It won't work with high brightness LED's I think. He can only try to know it
Old 3rd July 2010, 10:39 AM   #9
john_ellis is offline john_ellis  United Kingdom
Hi all
Unfortunately the old trick of checking the lower wire with the chip attached might not be a reliable guide - some LEDS have anode substrate others cathode substrate.
Many LEDS are not able to handle high reverse voltages. Even a 9V battery used in many digital meters might be too high (according to the data sheet).
The forward voltage of a LED might be too high for measuring the resistances on an old meter with 1.5V battery (and Avo's 15 V for high resistance may cause more damage).
Simplest way is to hook up a 4.5V battery through a 220 ohm resistor and see which way it lights.
Cheers
John
Old 3rd July 2010, 11:14 AM   #10
On Hiatus
SY's Avatar
LED polarity
With packages like T1 and its relatives, the cathode is marked by a small flat spot on the rim.
Pease uses a battery and resistor, FWIW.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
LED polarityHide this!Advertise here!
LED cathode bias - how to pick LED? sharpi31 Tubes / Valves 32 9th November 2010 09:55 AM
LED polarity guitargully Solid State 4 12th January 2004 05:14 AM
