Construction Tips Construction techniques and tips
LM3916 VU meter circuit
Old 19th June 2010, 04:49 PM   #1
seroxatmad is offline seroxatmad  United Kingdom
seroxatmad's Avatar
Default LM3916 VU meter circuit
Hi
Looking at the attached pic can anyone advise for using the circuit in bar mode!
JB1,2,3,4 and JD1,2
Looking at the lm3916 pdf says connect pin 9 to +vcc for bar mode but what about JD1 and JD2?
Cheers
John
Head Amps:Millet Max / Kumisa CKIII |Speakers: Dali Opticon 8 |Amp:Roksan Kandy |CD:Roksan Kandy |TT: RegaP2 | Phones: Shure SRH1540
Old 19th June 2010, 05:12 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I think you asnwered your own question. JD1,2 connect pin 9 to Vcc or to the other connection to select DOT or BAR mode. Clearly, you want all four jumpers in the same position for a specific mode.
jd
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 19th June 2010, 05:55 PM   #3
seroxatmad's Avatar
Hi
Thanks for the reply - I assumed i would jumper JB1,2,3 and 4 but wasnt sure about JD1 and 2.
Cheers
John
P.S We met at chesterfield UK at the diy meet.
Old 19th June 2010, 08:39 PM   #4
jan.didden's Avatar
Originally Posted by seroxatmad View Post
[snip]P.S We met at chesterfield UK at the diy meet.
To darned long ago - you guys should throw another one!
jd
Old 28th June 2010, 10:11 PM   #5
seroxatmad's Avatar
I was thinking about having the bar/dot mode an option via a switch
Seems it may be a pain to figure out
John
Old 29th June 2010, 12:30 AM   #6
jan.didden's Avatar
John
Where's the pain? A DPDT switch?
jd
Old 29th June 2010, 06:35 AM   #7
seroxatmad's Avatar
Yes was thinking about a pcb mounted DPDT switch for JB1,2,3 and 4 but what about JD1 and 2?
Cheers
John
Old 29th June 2010, 07:23 AM   #8
jan.didden's Avatar
Cheers
John
OK for two channels you need a 4-pole switch, double throw. A bit less easy to find, yes.
Mouser gives 400 hits, like this one: PN42LESA02QE C&K Components Pushbutton Switches . $ 1.10 Or toggle types, hundreds.
http://nl.mouser.com/ProductDetail/N...ekQAxW0k38g%3d $ 10
jd
Old 29th June 2010, 07:32 AM   #9
seroxatmad's Avatar
What about JD1 and 2 are they shorted when JB1,2,3 and 4 are?
Cheers
John
Old 29th June 2010, 07:41 AM   #10
jan.didden's Avatar
Cheers
John
The 3916 data sheet should tell you which is connected to which in which mode.
jd
LM3916 VU meter circuitHide this!Advertise here!
Circuit for analog VU meter G.L. Tirebiter Chip Amps 10 12th December 2015 07:40 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
vu meter help cowanrg Parts 12 2nd September 2004 05:21 AM
VU meter nbcd Solid State 5 16th November 2003 09:02 PM
vu meter karma Pass Labs 17 19th April 2003 11:00 PM
