Construction Tips Construction techniques and tips
My contribution to this site...if anyone is interested.
Old 5th April 2012, 04:18 AM   #221
sakellogg is offline sakellogg  United States
sakellogg's Avatar
Originally Posted by aptquark View Post
OMG...you dont know who Early is? See Squidbillies.
I think he's one of my long lost relatives.
i like the grandma.
I'm not crazy, my mother had me tested
Old 5th April 2012, 05:31 AM   #222
bear is offline bear
expert in tautology
bear's Avatar
bet you lose...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 5th April 2012, 10:33 AM   #223
aptquark is offline aptquark  United States
aptquark's Avatar
lol...I cant believe Im turning you guys on to the squidbillies...this is a sad day at DIYA. The Grandma is insane, but Dan Halen takes the cake!
Thanks for the info Benb.
Bear...suddenly I regret making the challenge. DAMN MY INSOLENCE!
BTW...I cant find a good explanation of shunt capacitance anywhere online...either that or I have no idea what Im reading. Damnit I should have studied EE back in the day
Old 5th April 2012, 10:43 AM   #224
Just follow this Forum with an open mind. I learn almost every day.
regards Andrew T.
Old 5th April 2012, 10:53 AM   #225
aptquark's Avatar
Cheers AndrewT.
Old 5th April 2012, 09:21 PM   #226
Speedskater is online now Speedskater  United States
Speedskater's Avatar
Originally Posted by bear View Post
The voltage is irrelevant.
The issue is shunt capacitance, impedance WRT frequency based on the reactance that the capacitance presents at a given frequency
_-_-bear
With real-world interconnects and circuits, I don't think the math will show any problems.
A worst case scenario from Siegfried Linkwitz:
Cable capacitance 2 nF
If the output impedance from the preamp is 1kohm (high) and the input impedance of the power amp is 10kohm, then the effective impedance is 10k//1k or 910ohm.
With the 2nF cable this gives a lowpass 3dB cutoff frequency of Fc = 1/(2piRC) = 87 kHz, which is still far above the needed frequency range. With a typical capacitance cable the cutoff would be at 350 kHz. If the passive preamp has 10kohm output resistance Fc would still be 70kHz.
Kevin
Old 5th April 2012, 10:42 PM   #227
alazira is offline alazira  United States
alazira's Avatar
I have read posts1 & 10.
I am still lost as to how you arrived at those conclusions.
Hi AndrewT,
One example:
Aptquark is showing us a design that uses a Cu/Ag twisted pair for the signal.
Aptquark claims to have tested all design variations. If I am to take his word for this, then he has at least tested single Cu, single Ag, twisted Cu, twisted Ag, etc.
Therefore, I concluded that to Aptquark's ears, he prefers the Cu/Ag twisted pair over single Cu, single Ag, etc.
Old 6th April 2012, 12:52 AM   #228
expert in tautology
bear's Avatar
the typical input Z is 47kohm or higher, often 100kohm.
it matters a bunch in phono set ups...
and regardless of where the formula says it ends up, it somehow comes out being audible...
at least in my experience.
_-_-bear
_-_-bear
Old 6th April 2012, 02:02 AM   #229
aptquark's Avatar
_-_-bear
phono for sure...my TT had some wires that for reasons I cant remember I replaced with my silver ones. It sounded good...but at some point I wanted to go back to the originals. The TT is an Origin Live, with their propriatery wires. I contacted the distributor in Ca. and he ordered some from OL. They were expensive...to the point where I was flabergasted. Too late though...they were ordered. Once I got them and replaced the silvers...I then realized that it was worth the cost. I never inquired as to their composition...but they are copper/cotton.
Old 6th April 2012, 10:18 AM   #230
Originally Posted by alazira View Post
Hi AndrewT,
One example:
I see now, you are summarising his conclusions.
I read your post as summarising your conclusions.
Sorry for the confusion.
Use quotes to separate your thoughts from the fiction
regards Andrew T.
My contribution to this site...if anyone is interested.Hide this!Advertise here!
Contribution to loudspeaker wiki? hkoetz Multi-Way 3 2nd March 2008 08:45 PM
My small contribution syn08 Solid State 15 15th January 2007 01:41 PM
audioPT's gainclone mania contribution audioPT Chip Amps 2 5th July 2005 03:58 AM
Copyright ©1999-2017 diyAudio
