Construction Tips Construction techniques and tips
My contribution to this site...if anyone is interested.
Old 24th June 2010, 11:02 AM   #131
aptquark is offline aptquark  United States
aptquark's Avatar
Now push your conductor through. Bend the end slightly so it doesn't catch itself inside the cotton and prohibit the wire from moving further. A 28 gauge wire will slide through very easily. Shown here is my 28 gauge silver/copper wound wires. I will show you how to do this later on.
Old 24th June 2010, 11:07 AM   #132
aptquark's Avatar
Later I will continue with the connectors. This is a little tricky because you are now working with a completed cable (including the texflex jacket you see pictured), and are somewhat limited to how you can manipulate the ends. The difficulty will depend on what type of RCA's you use.
Don't start building these yet...I haven't show the little trick I use to keep the cable from breaking.
Adiós for now.
Old 24th June 2010, 03:20 PM   #133
quadzilla is offline quadzilla
Originally Posted by Globulator View Post
Is there any proof that less resistance sounds better? If this was the case surely transistors would always sound better? What about anode resistors, grid stoppers etc?
There are many who will tell you that transistors do sound better. That said, if I'm not mistaken, resistance affects frequencies differently. High frequencies, even within the audible range, are affected more than low frequencies. Resistance also causes time domain issues. See e.g. Skin Effect and cable impedance
When you can demonstrate to me in a scientific manner why two people love each other, I will demonstrate to you in a scientific manner how to tell which pair of cables will sound best in your system.
Old 24th June 2010, 03:49 PM   #134
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Adiós for now.
Hey i have a whole PILE of cotton tube rope you can have, if you pay the shipping you can have it or trade for something. Its just sitting here collecting dust about 75 feet of it.
Old 24th June 2010, 06:47 PM   #135
aptquark's Avatar
Thanks for the offer. I have 40 packs myself. Nice collection of sheathing. What do you use for shielding?
Old 24th June 2010, 08:54 PM   #136
Banned
I use silver teflon wire from a guy in the states, its like coax but smaller i like it and its what i have been using, i also use silver wire braided for my speaker cables.
Old 25th June 2010, 02:29 AM   #137
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
its a fact that water always runs/turns th same way, due to earth magnet field
it can be seen when draining a bathtub
but I believe it turns differently in different parts of the world
any idea if this also affects the way wires are twisted
and its not a joke
sometimes we know very little, and sometimes we know too much
Old 25th June 2010, 11:32 AM   #138
aptquark's Avatar
and its not a joke
After having experimented with single solid core 28 gauge cables, I wanted to try a few alternatives like a thicker gauge, combining Au and Cu together, and using different positive and negative return configurations. I believe that the Au/Cu wound wires have the best overall balanced sound. I could hear a subtle difference when using my Gamut amp. The Gamut is a strange beast. Many say that it lacks in bass resolution. And at first, I wanted to agree. BUT, after listening to quite a few albums...this is not the case. It has a unique way of delivering precisely how the material was mastered. For example, I find RADIOHEAD to be strangely mastered. Over emphasis on the bass guitar, yet weak in bass drum expression. Don't get me wrong...they rock of course. But for some reason, the Gamut balances this out, and produces a more balanced sound between the two. The Au/Cu combination extended the bass drum signature and, for the first time, I was pleased with the representation. I tried more albums that I found to be mastered similarly. And sure enough, I observed the same characteristics. Technically, I think that it has to do with the slightly larger gauge that the Au/Cu combination allows BUT configured in a twisted morphology. Oddly, running Au and Cu in a paralleled fashion did not produce the same result. Another interesting note is that I also noticed that using a Au/Cu twisted positive conductor WITH a single Cu negative conductor displayed no difference than a Au/Cu double run. Initially, choosing the 28 gauge size was due to my belief that it would reduce skin effect issues. Possibly, the larger gauge combination of the Au/Cu provided less resistance, thus producing the above mentioned differences in signature. Unfortunately, real means of technically measuring this is out of my league. But my ears don't lie. I'm also a strict believer in controlled experiments.
Spiro
Old 25th June 2010, 11:53 AM   #139
its a fact that water always runs/turns th same way, due to earth magnet field........... I believe it turns differently in different parts of the world
I thought I remember reading that it was the spinning of Earth on it's axis that determined the direction of plughole drainage.
I also thought the northern Hemisphere behaved in opposite direction to the Southern Hemisphere.
Are you suggesting that the Brazilian and Ossie Members should twist their cables differently from us Northerners? Surely not?
regards Andrew T.
Old 25th June 2010, 12:25 PM   #140
aptquark's Avatar
It depends how one is viewing the drain. If you stand facing it, it goes one way. If you stand across from it...it goes the other way. It's all in the mind my dear Watson.
My contribution to this site...if anyone is interested.Hide this!Advertise here!
Contribution to loudspeaker wiki? hkoetz Multi-Way 3 2nd March 2008 08:45 PM
My small contribution syn08 Solid State 15 15th January 2007 01:41 PM
audioPT's gainclone mania contribution audioPT Chip Amps 2 5th July 2005 03:58 AM
Copyright ©1999-2017 diyAudio
