Buffer for long cable capacitance - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 28th May 2010, 03:47 PM   #1
trv is offline trv  Israel
Default Buffer for long cable capacitance
Hi all,
As I understand the guitar cable line is like a capacitor, as long as the cable is, the high cable capacitance is, that's why long cable results high freq loss (capacitor in parallel to signal), solution for this is the buffer.
Buffer has low output resistance, how does it prevent the high freq loss?
What is the considerations and triad off for selecting buffer's input & output resistor ?
Old 28th May 2010, 04:20 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
Audio Buffer in english
No problem to drive 100m or more.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 28th May 2010, 04:30 PM   #3
pilli is offline pilli  France
If the buffer is "before" the cable
(that is between the pickup+pots and the cable)
then the buffer output resistance (which is low) defines the RC
instead of the pickup + potentiometers output R.
The corner frequency of the filter is 1 / (2 * pi * RC)
so the smaller the RC, the further up your corner frequency.
The buffer also has a high input resistance, thereby "isolating" the pickup.
_
Old 28th May 2010, 04:33 PM   #4
PMA's Avatar
In case you match series and terminating impedance to cable characteristic impedance, then you avoid capacitive loading rule and you can send signal to several hundred meters without problem.
Pavel Macura
Old 28th May 2010, 05:18 PM   #5
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Put the buffer with 75R output resistor at the transmitting end of cable. Use 75R cable (like coax). Insert 75R resistor across signal and ground at the receiving end of cable or on input of amplifier/mixer/what ever. Works every time
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 28th May 2010, 06:05 PM   #6
So why most of guitar effects has about 10k to 100k resistor at the output buffer?
Old 28th May 2010, 06:47 PM   #7
correction:
the 10k to 100k resistor is in parallel and not in serial
Old 28th May 2010, 07:10 PM   #8
Jan Dupont's Avatar
In both cases. Maybe because they didn't take long leads into considerations................
Old 28th May 2010, 07:27 PM   #9
Talking about impedance matching, guitar pickup resistance is about 10k.
Why in many guitar effects there is a big resistor (100k to 1M) in parallel in the input of the entry buffer?
Old 28th May 2010, 07:35 PM   #10
Jan Dupont's Avatar
I'm in no where into "live" gear, but mostly the reason to high input impedance is to provide as high load as possible for the equipment connected to it (to minimize Current need at the output). Two different worlds.....
Speaker Cable Capacitance and Amplfier Stability JCLNV Everything Else 17 24th December 2007 03:49 PM
Coaxial Cable Capacitance -_nando-_ Parts 2 17th March 2007 05:13 PM
Zobel for high capacitance cable kiang Multi-Way 0 11th July 2005 10:52 AM
ZEN vs. high capacitance diy speaker cable? Vix Pass Labs 8 5th March 2004 12:31 AM
Cable capacitance Prune Everything Else 7 8th February 2004 11:34 AM
Copyright 1999-2017 diyAudio
