| Construction Tips Construction techniques and tips |
First of all I have to mention that this technique involves a certain amount of risk of getting shocked because it involves exposed electrical connections. This technique is somewhat advanced and should not be undertaked by beginers. This is a way I use to quickly prototype a tube circut in the early stages of proving it out. I cut some double sided copper clad PCB material into thin strips about 1/8" wide and mabe 1/2" long and glue them down on another piece of the same material with super glue. This provides insulated "islands" that then can be soldered to. Tube sockets and other componets can be mounted and interconnected and a circut built up.
#2 |
See here the assembled board under test. It took one sitting to build a working circut and provides a way to change parts and values on the fly. Also it should be mentioned that this is no way to build a perminate circut! Don't try to build a finished product this way, as the glue has a strong tendancy to break lose and voltages can end up in the wrong place
I would like to hear opnions and perhaps others suggestions for techniques to achieve the same goal. |
#3 |
Cool.
I had a customer who needed a male connector for an old amplifier - so he made one. Carved a connector body from a piece of maple, then glued in metal pins and so on. Worked fine. I was impressed by the effort and thought he put into a simple connector. Myself I would have just bought one. I think your little board is clever. But there are commercial product of similar nature. Antique Electronic Supply sells a variety of terminal boards with tube sockets mounted. They come in 9-pin, octal, and even a 4-pin. The boards have one, two, or three sockets. Each board has two or three rows of turret pins to solder parts to. SOme examples one 9-pin with three rows, stock #P-TB9-1-3 http://www.tubesandmore.com/cemirror/inv/P-TB9-1-3.GIF two 9-pin with two rows http://www.tubesandmore.com/cemirror/inv/P-TB9-2-2.GIF dual octal http://www.tubesandmore.com/cemirror/inv/P-TB8-2-2.GIF And a couple designed specifically for old Dynaco circuits. And for octal tubes there are things sold as "relay sockets" that are basically a plastic block with an octal socket, then a row of srew terminals along the side - one per pin. AES sells those too, but relay sockets are also sold throgh parts houses like Mouser http://www.tubesandmore.com/cemirror/inv/P-ST8-108S.GIF |
#4 |
Yes Enzo, That is a good piece. Several steps better than what I propose. One could even build a circut on those boards and incorporate it into a final amp design. They could also be reused. I am a big fan of AES. I buy a good bit of my parts from them.
Bob |
| ECL86 - quick and dirty | beamnet | Tubes / Valves | 44 | 1st April 2012 06:54 AM |
| quick n dirty volume control | JL888 | Analog Line Level | 6 | 19th May 2010 09:50 PM |
| quick and dirty Mono Sum circuit | cranberry | Analog Line Level | 2 | 7th September 2009 02:08 PM |
| Quick and Dirty X-over | bjackson | Solid State | 1 | 16th August 2005 06:32 AM |
| OTL, quick `n dirty | Fuling | Tubes / Valves | 4 | 27th December 2004 07:44 AM |
