Construction Tips Construction techniques and tips
Making beat-up ReVox B77 loook nice on almost zero budget
Old 2nd April 2010, 04:34 PM   #1
Steerpike is offline Steerpike
Steerpike's Avatar
Default Making beat-up ReVox B77 loook nice on almost zero budget
A couple of weeks ago I bought a B77 for $25. It looked bad, but since it's my favourite tape recorder model of all time, I couldn't leave it. I thought it would at least be good for spares, but some inspiration brought it back to 'showpiece condition'.
As I got it, (a) all the toggle switches had been broken off, (b) someone had put something hot on the top of the cabinet in from of the handle, which melted a droop in & blistered the cabinet, (c) the Nextel was generally very scratched and worn.
For the toggle switches I made 'fakes' by filing & machining down two glued-together strips of acrylic, cut from an old cracked turntable cover; I needed double thickness, so two strips. Then I drilled & painted these metallic silver. A short section of 2mm welding rod connects these new fake dollies to the original switch toggle mechanism, into the centre of which I drilled a 2mm hole.
The burned cabinet top I 'hid' by carving out a rectangular recess, using a chisel & craft knife. Into this recess I slotted a section of aluminium extrusion from the hardware store. It matches the pinch roller cover flap perfectly.
I removed all the Nextel with methylated spirits, and re-sprayed it in Satin Black aerosol paint (2 x $5 cans).
Various scrapes and scratches on the amplifier face and reel taples I touched up with Humbrol model paint & a tiny brush.
It looks pretty now!
Steerpike's Toybox
Old 8th April 2010, 03:09 PM   #2
ermine is offline ermine  United Kingdom
nice work
Old 2nd January 2011, 05:16 PM   #3
MurphyB77 is offline MurphyB77  Canada
Thumbs up Your B77 revival
I found the same machine for 20 bucks!
Another 100 brought it back to near mint condition.
Still short two silver switches, but I might try your
Thanks for posting!
Happy and safe 2011
Making beat-up ReVox B77 loook nice on almost zero budgetHide this!Advertise here!
ReVox B77 PSU upgrade Steerpike Analogue Source 0 11th March 2010 05:39 PM
FS: Revox B77 Oscillator PCB lcsaszar Swap Meet 0 30th May 2009 01:43 PM
What exactly happens here ? Revox B77-mkII DK6400Brian Analogue Source 6 30th November 2007 02:56 AM
How much should I pay for a Revox B77? acidbasement Analogue Source 4 15th June 2007 06:23 AM
Revox B77 problems erdebear Analogue Source 10 8th October 2005 05:35 PM
