glue for surround? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 10th March 2010, 08:27 PM   #1
Send a message via Yahoo to scampo77
Default glue for surround?
im working on a kicker square speaker and the surround is made of rubber. i wish i could describe it better but i dont know much about different kinds of rubber all i know is that its black. im trying to glue it to a aluminum cage. right now im using contact cement and it seems to stick to the aluminum but not at all to the rubber surround. ive tried scuffing it up and cleaning the rubber but nothing will stick. i dont want to use expoxy because it would be expensive and im guessing it would try to hard.
any ideas?
Old 11th March 2010, 12:06 AM   #2
Enzo is offline Enzo  United States
Look at PArts Express. they sell a lot of speaker related stuff, including recone materials. I couldn;t tell you if there is a special speaker cement for rubber, but it is a place to start.
Also, google "speaker reconing", I know that gets you to a number of suppliers
Old 11th March 2010, 01:29 AM   #3
expert in tautology
bear's Avatar
standard contact cement is solvent based, very very bad on foam.
often corrodes metals too...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 11th March 2010, 01:37 AM   #4
Hello scampo77, here's two website below of adhesive manufacturers. There are many others. I know both make adhesives tailored to gluing rubber. I would say it's best to poke around here and on google and see what you find. Don't forget to read the details about the adhesives, and the MSDS. The MSDS will give you information about how dangerous the chemicals in the adhesive are, so you can decide if you are comfortable using it.
3M United States: Industrial Adhesives, specialty adhesives, double-sided, bonding, adhesive transfer tapes, reclosable fasteners, aerospace, architecture, construction, converters, electronics, transportation
Super Glue Corporation | Home of The Original Super Glueź
Peace,
Dave
Old 11th March 2010, 02:25 AM   #5
expert in tautology
bear's Avatar
Loctite makes most of the adhesives used in the speaker industry... or did...
_-_-bear
Old 14th March 2010, 08:31 PM   #6
thanks everyone i got ahold of a loctite sales rep and he sold me something called black contact adhesive part number 30540. it looks and smalls like contact cement but he said it is different.
i cleaned up the speaker cage and re glued it. it seems to be holding better then the regular contact cement, but who knows. ill put some horse power to the speaker and see how it holds up. ill keep everyone posted
again thanks for the info
Old 12th August 2010, 06:58 PM   #7
hispls is offline hispls  United States
"Amazing Goop" glue also works well for cone to surround and surround to basket. (Supposedly will do almost everything but I can only vouch for it in those applications) I run over 2KW into a sub I built up with that with no ill effects and I personally witnessed a 10" woofer repaired on the surround with it holding over 4KW
axial surround instead of radial surround Calvin Subwoofers 22 13th July 2009 06:46 PM
What glue to use feverdog873 Multi-Way 17 5th January 2009 11:46 PM
What glue to use? wixy Multi-Way 26 6th February 2007 11:49 AM
What type of glue for butyl rubber surround repair? c_h_shin Multi-Way 0 19th May 2004 05:37 AM
Question of how to glue driver surround to casket... stappvargen Multi-Way 16 13th January 2004 07:05 AM
Copyright ©1999-2017 diyAudio
