What veneer is this ? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 5th March 2010, 07:35 PM   #1
DIFORCE is offline DIFORCE  Australia
Default What veneer is this ?
I really like to veneer my speakers this way , With that mirror finish . Anyone knows what kind of veneer is this and how to achive this mirror finish ?
Old 5th March 2010, 07:39 PM   #2
MJL21193's Avatar
My guess is that it isn't veneer. Looks like a paint technique where successive layers of different colour paint is applied and once it is dry, they sand through some layers to get that effect.
The mirror finish is many coats of clear (either lacquer or polyurethane) then polished with polishing compound and a buffer.
Old 5th March 2010, 07:44 PM   #3
MJL21193's Avatar
Similar to this:
A little experiment I did a few years ago.
Old 5th March 2010, 07:48 PM   #4
event horizon's Avatar
What speakers are they? They look like something Sonus Faber would produce, in which case that will be a wood veneer at the very least, if not solid wood
Like John says, lots of layers of lacquer
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 5th March 2010, 07:51 PM   #5
5th element's Avatar
Some walnut burr/burl can look like that.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 5th March 2010, 07:56 PM   #6
Those are Raidho Ayra C1.0 , Seriously expensive ...
Old 5th March 2010, 08:02 PM   #7
MJL21193's Avatar
Says walnut burl on their site.
Old 5th March 2010, 08:55 PM   #8
Banned
It's hard to be sure from the photos, but from the way that the grain structure seems to wrap round the edges, it might be a technique called dip print. They're obviously not carved from a solid block of wood, so if the grain really does appear continuous from one face to another, then dip print might be the explanation.
Items to be wood printed are first painted a uniform brown.
A patterned plastic film is floated in a water tank and an activator sprayed on it which causes it to liquefy. The items are dipped into the floating film which adheres to the object intimately and wraps closely to it. The film is extremely thin, so a certain amount of overlapping is not readily visible in the finished product. The technique can be adapted to print whole objects at a single pass or component parts, dependent on the exact finish required.
The effect can be extremely convincing.
w
Old 5th March 2010, 09:03 PM   #9
MJL21193's Avatar
w
I've seen that process in action but I think it's a bit "low rent" for such costly speakers.
Old 5th March 2010, 09:05 PM   #10
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Wonder if the wife would notice a pair of these???
Ayra C1.0 - 7,495.00per pair
2 Way Monitor Loudspeakers
Standard Premium Finishes: Walnut Burl Veneer
Ayra C1 by Raidho at High End cable
Restoring Veneer richie00boy Everything Else 30 26th March 2007 03:38 PM
veneer monomonster Multi-Way 12 26th November 2005 04:56 AM
Veneer? philipbarrett Full Range 3 8th November 2005 03:20 AM
Veneer on veneer?? sam9 Multi-Way 5 1st August 2003 07:21 AM
Veneer Nathan Multi-Way 21 11th May 2003 06:52 PM
Copyright 1999-2017 diyAudio
