What veneer is this ? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 5th March 2010, 09:03 PM   #11
InclinedPlane's Avatar
Beautiful, but I just can't justify paying more than a couple thousand USD for any passive monitor set.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 5th March 2010, 10:03 PM   #12
fredk1 is offline fredk1  Canada
What ever that is, the real thing (burled walnut veneer) is beautiful on speakers!
Old 8th March 2010, 06:55 PM   #13
The grain doesn't wrap around the edges. It is probably veneer.
Originally Posted by wakibaki View Post
It's hard to be sure from the photos, but from the way that the grain structure seems to wrap round the edges, it might be a technique called dip print. They're obviously not carved from a solid block of wood, so if the grain really does appear continuous from one face to another, then dip print might be the explanation.
Items to be wood printed are first painted a uniform brown.
A patterned plastic film is floated in a water tank and an activator sprayed on it which causes it to liquefy. The items are dipped into the floating film which adheres to the object intimately and wraps closely to it. The film is extremely thin, so a certain amount of overlapping is not readily visible in the finished product. The technique can be adapted to print whole objects at a single pass or component parts, dependent on the exact finish required.
The effect can be extremely convincing.
w
I was so much older then, I'm younger than that now.
Old 8th March 2010, 07:28 PM   #14
Martin Prothero's Avatar
Its not the veneer that bothers me, its the thought that it might be adhered to some MDF! Looks like American Walnut (I'm fro,m the UK and we differentiate between native and American). It also looks spalted hence the streaks.
Keep a green bough in your heart, the singing bird will come.
Old 10th March 2010, 01:35 PM   #15
jlsem is offline jlsem  United States
jlsem's Avatar
It's real veneer, but it's not walnut burl. It's butt walnut from the base of the tree and not of particularly high quality.
John
Restoring Veneer richie00boy Everything Else 30 26th March 2007 02:38 PM
veneer monomonster Multi-Way 12 26th November 2005 03:56 AM
Veneer? philipbarrett Full Range 3 8th November 2005 02:20 AM
Veneer on veneer?? sam9 Multi-Way 5 1st August 2003 06:21 AM
Veneer Nathan Multi-Way 21 11th May 2003 05:52 PM
Copyright 1999-2017 diyAudio
