DIY Schumann resonator? - Page 5 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 7th March 2010, 04:33 PM   #41
protos is offline protos  Greece
protos's Avatar
Another interesting study on the effects of ELF (extremely low freq) EM radiation .
http://www.mas.bg.ac.rs/istrazivanje...c%2093-103.pdf
If you do not want to read all of it skip to the end.
Perhaps for us the point may be that we do not have to get exactly 7.83hz to get desired effects.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.
Morgan Jones, Building Valve Amplifiers.
Old 7th March 2010, 05:03 PM   #42
analog_sa's Avatar
I have always assumed this much. As the ionosphere varies in height, a precise frequency seems unnecessary although making it user adjustable is probably important.
Not sure if i buy any of this New Age mumbo-jumbo anyway and suspect that the effect is entirely electrical. One of the reviews contains an interesting supporting experiment. The reviewer made recordings with the generator being both on and off and subsequently they sounded different.
Old 7th March 2010, 06:52 PM   #43
Eric Juaneda's Avatar
Default Amplifying local Schumann resonance
Originally Posted by analog_sa View Post
...a precise frequency seems unnecessary although making it user adjustable is probably important...
The ideal position might to synchronize with local Schumann resonance and made an amplification.
Is there any suggestion for a schematic?
Eric Juaneda - tech.Juaneda.com - Junilabs.com
Old 7th March 2010, 08:36 PM   #44
Eric your suggestion makes sense but this would imply that you then need a receiver circuit to catch on and then lock onto the Schumann resonance. So how do you do that? You would also want the two resonances to be in phase I think.
moray james
Old 8th March 2010, 03:01 AM   #45
Interesting site
www.vlf.it - ELF Minimal Loop
moray james
Old 8th March 2010, 05:30 AM   #46
Allen I just dug up some small step down transformers which have two 120 volt primary windings and are EI style will these work ok as a radiating antenna?
moray james
Old 8th March 2010, 04:24 PM   #47
I just found this site which has two basic and inexpensive units for sale.
KRT: ELF 7.8 Hz
moray james
Old 8th March 2010, 04:40 PM   #48
Hello moray,
Originally Posted by moray james View Post
This easy way to measure Schumann resonance is very interesting.
Old 8th March 2010, 06:22 PM   #49
Default CD player used as generator - step 2
I made some changes on my CD player used as a Schumann resonator to keep 2V RMS on output with 600 ohm load.
One output is directly wired to the output AOP (3V DC output), the other integrates a 100uF electrolytic capacitor to suppress the DC value. With 600 ohm load the output is about 3% lower with serial output capacitor.
I start CD player as Schumann resonator and perform a listening test comparison (listening audio system with various configuration on Schumann resonator). The direct output (including DC value) gives better results. After this first test, I made standards optimizations on the Schumann CD player by managing vibration.... Each improvements, improves rendering on listening audio system. It seems that more Schumann resonance steady and clean better results are.
I have also listened to a unit based on a 555 and a coil. In fact two units with minor differences in construction - one used a toroidal mains transformer. The effect was immediately audible and both units sounded distinctly different. Not sure if i really liked what it did but the mere audibility really impressed me. Could the effect be due to EMI?
It match with comparing test made by analog_sa on comparing power transformer on Schumann resonator.
Old 8th March 2010, 08:07 PM   #50
Default sign wave generator...
the Healing Earth generator produces sine wave output at 7.83 Hz with a variable output. See link below.
Healing Earth - Schumann Resonance
moray james
Resonator guitars PhaseLockLoopy Instruments and Amps 3 30th May 2008 04:28 PM
Cabinet brace act as helmholtz resonator? RyanW Multi-Way 17 2nd October 2007 11:08 PM
Horn-Resonator? TroelsM Multi-Way 5 29th September 2005 02:23 PM
isobaric resonator? tade Subwoofers 6 17th August 2005 07:24 AM
Ceramic resonator pinout trwh Digital Source 2 21st July 2002 12:35 PM
Copyright 1999-2017 diyAudio
