Construction Tips Construction techniques and tips
Speaker Testing Jig Assembly Thread
Old 16th October 2010, 02:09 PM   #51
johngalt47 is offline johngalt47  United States
Default How do you test speakers with this jig?
Is there a "cookbook" that tells how to do this similar to the "manual" Zaph laid out for Sound Easy?
Any technology sufficiently advanced is indistinguishable from magic
Old 17th October 2010, 11:38 AM   #52
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
One was promised. I haven't seen it
Old 7th November 2010, 11:43 AM   #53
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Originally Posted by MJL21193 View Post
I will start up a thread on that subject once a few of these have been assembled.
Sorry to all for the long delay.
I will get back into the swing of things shortly and your continued patience is appreciated.
The jig is a modified version of the Wallin jig and the use of it is nearly identical. There is a ton of documentation on using Speaker Workshop with a jig like this. HERE is a good place to start.
I'll get the setup thread on track as soon as possible.
Old 15th May 2011, 07:24 PM   #54
ra7 is offline ra7  United States
Any word on the user's manual thread? I just finished assembling the board and everything seems to be ok. Can't wait to start making impedance measurements.
Old 23rd October 2012, 12:00 AM   #55
Siggma is offline Siggma  United States
Siggma's Avatar
Here are detailed instructions for assembly of the speaker testing jig designed HERE.
Please let me finish posting all of the instructions before you contribute or ask a question.
First, I know this is an old thread. It's also apparent the maker of this jig never created the user manual he promised. As I recently purchased an unassembled jig kit and it actually works I'll be happy to share what I learn and have learned as I go starting with getting it working.
If anybody still has one of these jigs and didn't get it to work the instructions left out two very important PARTS-SIDE jumpers that are marked on the board but not mentioned in the instructions. I fussed with the one I recently purchased and only noticed that in the pictures there are jumpers on the board where they are outlined in white but they aren't mentioned in the instructions. Once I installed the jumpers it seems to work fine.
Also of interest, I decided to use a full 24v PS and although it seems to work fine the resistor for the LED (R1) is only 1/8 watt and starts to get hot and stink after only a a minute or two. Thankfully the transformer I bought is a 24v secondary winding with a center tap so I can just switch to 12v and not have to replace the R1 resistor but it seems the only solution is to replace it with a 1/4 or 1/2 watt version. I haven't seen any other issues with the jig so far.
If anybody has one of these and is using it can you verify the IMP measurement procedure?
It seems the logical way to do this is with only 1 set of probes. It would seem obvious to get two dual banana connectors (red & black) and place one between both RED test lead plugs and the other between both black plugs. Then run the testing leads (12Gauge Monster wire?) down to the speaker for testing and clip them on. This should use the jig amp to excite the speaker and the IMP line-in to measure it. I was hoping I wouldn't need to purchase two sets of test leads. Monster wire is very expensive.
Old 23rd October 2012, 12:15 AM   #56
mattlong8 is offline mattlong8  United States
mattlong8's Avatar
Default Monster wire
Siggma,
you don't have to use monster wire. You can go to your local electrical supply and pick up 2 different color 12 gauge stranded wire and twist them around each other for noise rejection.
-Matt
Old 23rd October 2012, 07:07 AM   #57
Go ahead, splurge a little:
Test Leads, Banana Plugs to Micro Clips, 34in.-MPJA, Inc.
for $1.95
Old 13th January 2013, 03:35 PM   #58
swantzilla is offline swantzilla
In know we have grown older since this thread was started but are the kits still available?
Old 16th January 2013, 12:04 AM   #59
critofur is offline critofur  United States
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
I have one assembled that I used a few times, I'd be willing to sell it for the original price. Meaning that I wasn't trying to sell it, but if somebody wanted one and they'd get more use out of it, then I guess I don't mind selling it. Mine is painted with Rustoleum "hammered" dark grey semi-metallic paint. If you're interested I could take a picture of it later this week.
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 19th January 2016, 11:49 PM   #60
critofur's Avatar
I'm sad that MJL21193 hasn't come back. I wonder if he's OK? I think it's time that I try to use this little jig again soon.
I might pickup some of these:
"Heavy Duty" 1m Banana Plug to "Mini Clip Test Leads
Speaker Testing Jig Assembly ThreadHide this!Advertise here!
Troels' PMS (multilayer assembly) build thread WaveFlex Multi-Way 129 3rd September 2014 04:09 PM
Speaker Testing Jig PC board / Kit MJL21193 Swap Meet 30 17th October 2010 01:19 PM
High Bid Auction! Speaker Testing Jig. MJL21193 Multi-Way 74 10th February 2010 10:24 PM
Wallin Jig v2 for Speaker Workshop 454Casull Multi-Way 11 20th March 2009 02:56 AM
Thiel-small Testing Jig palesha Multi-Way 2 6th February 2003 03:06 PM
