Construction Tips Construction techniques and tips
Speaker Testing Jig Assembly Thread
Old 15th March 2010, 07:11 PM   #31
OldMike2 is offline OldMike2  Canada
Default Jumpers
John,
Just finished building my Jig, great quality. You might want to include the jumpers in your instructions, get a sense that some of those who build this may be newbies and miss the need for them. I read your assembly instructions and did not find a refernce to them.
Mike
Old 16th March 2010, 12:03 AM   #32
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Hi Mike,
Yes, I thought of that after and I've been meaning to get a mod to insert a post in there covering it but I've just been too busy.
The new boards have "jumper" printed on in the silkscreen:
It's hard to think of everything - we have a "work in progress" here.
Glad you like the jig - have you tried it yet?
Old 16th March 2010, 03:04 AM   #33
Default Time
Not tried it yet,
I'm in the process of finishing a new house in the country and if I set up my new electronics room before I finish the WAF will drop to zero, hope to be in a position to "indulge" in about 6 months.
Mike
Old 16th March 2010, 06:56 PM   #34
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Originally Posted by MJL21193 View Post
Hi Duda,
I used 2 products in finishing mine and both are in spray cans.
This can give a pretty good paint job for less than $20.
Hope that helps
Thanks John - I think I can managed that...
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 29th March 2010, 08:45 PM   #35
40 watt is offline 40 watt  Canada
For the wall wart I have on hand a Hon-Kwang Class 2 transformer: It came from some Christmas light LED string thingy...which never worked right and pissed my mom off a few years back. It would light up and then shut off quickly. One of those multi-color, multi program thingies.
Input: 120V 60Hz 18W
Output:12VAC 840mA
so...840mA= .840A.
Suitability: at least for testing or temporary use 'til I find a bigger one?
A]: "...more power, Scotty!"
B]: "...she can't take much more of this, Captain!"
C]: "...Beam me up Scotty...there's no intelligent life here!"
Old 30th March 2010, 04:09 PM   #36
R.I.P.
well done MJL.
Everything fits.
I am glad I did not have to source all the hardware to fit those footprints.
Can someone confirm the orientation of the ON LED? I think the LED flat goes to SW2 side and the longer leg faces towards the outside of the PCB.
Thanks for all your efforts.
regards Andrew T.
Old 30th March 2010, 06:41 PM   #37
I put the LED flat side [cathode, short lead, or negative] facing to the inner portion of the panel and the other lead [anode, long lead, positive] to the outside of the front panel. I could well be very wrong on this.
I do recall being confused because of trace route FROM LED through R1, through jumper and over to negative side of 4700uf capacitor.
The other trace route comes direct from diodes.
The confusing part is I'm more familiar with the resistor in series on the power supply side, and now it's been awhile since I assembled it so it's not that fresh on the brain.
I haven't run any power through it yet, though...
I think I based my logic for install on this diagram:
Old 30th March 2010, 07:19 PM   #38
I think my wall wart has the wrong diameter inner hole for the out plug. i suspect 2.5mm or greater, though the outside barrel is correct.
So...I'll change plug barrel or just get the 1 amp unit.
Now I recall the wall wart came from a small Christmas tree on a rotating stand with a single bright bulb at its base and fiber optic lines above the glass [mulit-color] lens the fiber optic lines change color as the tree spins.
I have been thinking of adapting parts for a psychedelic volume control bezel for a preamp, with small dots of light around the bezel changing color as the volume increases to full volume showing the atomic symbol, all lit up nice and bright with extra strands of light pipes. Johhn's face-plate etching would be a perfect methodology for this custom bezel circumferencing the volume knob.
I digress...as usual.
Old 30th March 2010, 07:42 PM   #39
454Casull is offline 454Casull  Canada
I didn't read too much of the thread but it looks like you might have a 5.5mm/2.1mm and need a 5.5mm/2.5mm.
Old 30th March 2010, 08:04 PM   #40
I don't know what sise my plug is but it seems sloppy a bit when fitting over the male inner prong on the board input until the outer barrel centers it well.
That inner male prong on the circuit board looks smaller than my transformer plug orifice, but 4/10 of a mm is hard to judge.
Speaker Testing Jig Assembly ThreadHide this!Advertise here!
Troels' PMS (multilayer assembly) build thread WaveFlex Multi-Way 129 3rd September 2014 04:09 PM
Speaker Testing Jig PC board / Kit MJL21193 Swap Meet 30 17th October 2010 01:19 PM
High Bid Auction! Speaker Testing Jig. MJL21193 Multi-Way 74 10th February 2010 10:24 PM
Wallin Jig v2 for Speaker Workshop 454Casull Multi-Way 11 20th March 2009 02:56 AM
Thiel-small Testing Jig palesha Multi-Way 2 6th February 2003 03:06 PM
