Speaker Testing Jig Assembly Thread - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 25th February 2010, 11:05 PM   #11
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Man of Action!...that man is fast...whew!
Old 3rd March 2010, 03:44 PM   #12
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Could you post one closeup/medium-hires picture of the assembled board so that we (who don't remember resistor color band coding) can go by your picture to place the appropriate resistors in their correct spots? I can somewhat see from the picture you already posted, but some are not quite clear...
Thanks!
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 3rd March 2010, 06:28 PM   #13
MJL21193's Avatar
Hi critofur,
Like I said here:
Originally Posted by MJL21193 View Post
The resistors are not marked and it is best to measure them with a multimeter anyway before installing them.
It is always a good idea to actually measure the resistors before placing them. I do this on everything I make.
I'll post a pic a bit latter. I don't have one on file.
Old 3rd March 2010, 06:47 PM   #14
critofur's Avatar
I had misplaced my meter, found it now I'm good to go... I'll measure, like you recommend.
Cool - the 30s are 30.0 Guess my meter is only good to three digits. Shows how much I know about DMMs... The 1K shows 1.000 K.
The 68K measures 67.8 - is there any need to make note of that value - I'm guessing it's not used in a position that will affect calibration (but I don't know, didn't go through the circuit diagram to see what that one is doing).
Critofur
Old 3rd March 2010, 07:15 PM   #15
MJL21193's Avatar
All of the resistors are 1% tolerance and accuracy isn't critical, no need to note the actual values.
The three 30 ohm resistors paralleled should give a very accurate 10 ohms - this exact value is needed for later calibration.
Old 3rd March 2010, 07:45 PM   #16
critofur's Avatar
I assumed that's why you used three, and that they are used as the 10.0 Ohm resistor used both for calibration, and, for impedance measurements - is it not used for impedance?
Is the other triplet done for increased power handling?
Critofur
Old 4th March 2010, 03:19 AM   #17
critofur's Avatar
Ok, I've finished building the board, all that's left is to paint the case...
...Connect a suitable AC power adapter (12-24VAC, 1 amp) and turn it on..
I just realized - all my power supplies are DC. The recent technology switching power supplies (much lighter "wall warts") - do you think those come in AC?
Any suggestions on which power supply choices would be good / good value?
Hope to try this sucker soon.
Thanks,
Chris
EDIT: How about this? http://cgi.ebay.com/ws/eBayISAPI.dll...m=200416808189
Old 4th March 2010, 12:07 PM   #18
MJL21193's Avatar
The paralleled 30 ohm resistors make up the internal "known" load of the jig.
I'll go through calibration for Speaker Workshop (to measure driver impedance and other specs) in a new thread that I'll start soon.
EDIT: How about this? HP C4557-60004 AC ADAPTER +18V 1.7A WARRANTY 30 DAYS - eBay (item 200416808189 end time Mar-10-10 16:43:33 PST)
The adapter you linked to is not AC output either.
The one I used is this one: AC to AC adapter 12VAC, 1Amp
I made a mistake earlier when I said 12-24VAC, it should be 12 to 16VAC, 1 amp. The power supply smoothing cap is rated to 25V. The jig operates perfectly on 12VAC at 1 amp and that is the voltage I recommend.
Old 4th March 2010, 11:08 PM   #19
critofur's Avatar
Hmm, that one doesn't come with a plug, but this one does:
Critofur
Old 4th March 2010, 11:12 PM   #20
MJL21193's Avatar
Perfect!
Troels' PMS (multilayer assembly) build thread WaveFlex Multi-Way 129 3rd September 2014 04:09 PM
Speaker Testing Jig PC board / Kit MJL21193 Swap Meet 30 17th October 2010 01:19 PM
High Bid Auction! Speaker Testing Jig. MJL21193 Multi-Way 74 10th February 2010 10:24 PM
Wallin Jig v2 for Speaker Workshop 454Casull Multi-Way 11 20th March 2009 02:56 AM
Thiel-small Testing Jig palesha Multi-Way 2 6th February 2003 03:06 PM
Copyright 1999-2017 diyAudio
