Construction Tips Construction techniques and tips
How do I open a can?
Old 21st February 2010, 06:34 PM   #1
lcsaszar is offline lcsaszar  Hungary
Default How do I open a can?
I would like to open this OCXO without damaging it. It is a metal can soldered around its edge. The size is about 2" x 2". Any recommendations welcome.
Old 21st February 2010, 06:41 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Just a guess... put the whole thing on a hot plate and take a small brazing torch to the business end with a small pry bar lift up on the cover. Careful knowing there's wires attached.
Old 21st February 2010, 07:49 PM   #3
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Use a Dremel with an abrasive cutting blade to cut through most of the solder. Pry it open.
Old 21st February 2010, 08:05 PM   #4
wakibaki is offline wakibaki  United Kingdom
Banned
+1 for the Dremel.
I have diamond disks which in this case I'd use in preference to the stone disks which cast off a lot of grit.
w
Old 22nd February 2010, 09:21 AM   #5
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
Originally Posted by wakibaki View Post
+1 for the Dremel.
w
you forgot to mention it sends off shrapnel everywhere when it gets caught and shatters.
Old 24th February 2010, 06:21 PM   #6
Thanks for the tips. I am afraid the case and the internal part are tight fit, not giving place for the thickness of the Dremel blade. I probably try with a gas torch.
And what about the rounded corners?
Old 2nd March 2010, 12:49 PM   #7
wotsupnow is offline wotsupnow  United Kingdom
Have you tried desoldering braid ?
Old 2nd March 2010, 08:33 PM   #8
Pit Hinder is offline Pit Hinder  Germany
Pit Hinder's Avatar
Send a message via ICQ to Pit Hinder
Maaan, you must be as fossilized as any dinosaur! Heat and braid, no superputer mega$ gizmo...Id offer a handshake, but Im afraid to spill my wine.
Old 3rd March 2010, 06:29 PM   #9
Heat... well, this is the problem. The big mass of the enclosure conducts away the heat from the tip of my soldering iron. Perhaps a gas torch would do, but I am afraid that I damage the internals...
Old 3rd March 2010, 06:31 PM   #10
MJL21193's Avatar
What are you trying to save? The guts or the case? Sacrifice the case like we said above - cut it and pry it open.
How do I open a can?Hide this!Advertise here!
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 10:35 PM
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 08:58 PM
