How to cut holes for drivers with truncated frame - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 18th February 2010, 04:29 PM   #1
giralfino's Avatar
Default How to cut holes for drivers with truncated frame
Hi all,
I would like to countersink a driver with a truncated frame (Peerless 830875), but I don't know how to do the non circular cutout in the baffle. I successfully used a hand router with a simple jig (wood and nail) for round cutouts. Filling the part is not an option.
Thanks, Ralf
Old 18th February 2010, 04:59 PM   #2
trd1587 is offline trd1587  Canada
trd1587's Avatar
use the jigsaw with a guide. If teh guide is not attached to the saw, make one yourself out of a straight edge that you clip to you piece you need to cut
Edit: You can use your router the way also. A straight edge on the outside off the router parrallel to your cutting.
I Hope you understand What I try to explain. I know a drawing would be better, but I suck big time at that.
Old 18th February 2010, 08:04 PM   #3
smokinghot's Avatar
Well assuming you're using more than one driver in your project, I'd suggest making a jig to guide a "flush trim bit" used in your router. Something that you'll have to design to be be easily clamped to your baffle, and have markings to ensure alignment.
Most routers can use an edge guide like this, (trd's suggestion):
http://catalog.sears.ca/wcsstore/Mas...0007_1_271.jpg
Use that guide to develop your truncated edges, and a standard circle jig for the rest.
Jigsaws are messy, and if you do develop a jig any rough cuts will be transferred to your baffle.
Jarrett
DIY addict
Old 19th February 2010, 01:09 PM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Make a jig and use a jig guide on the router (see pic). The jig is cut oversize and is related to the bit size and jig guide collar.
Some builders are tricky and route out the round hole but use mouldings in the vertical edges of the speaker which gives the flat surface. See this example from Andy G.
Andy G's Trinity
No longer DIY active
Old 19th February 2010, 01:47 PM   #5
giralfino's Avatar
Thanks for the suggestions.
So the difficult task is to make a good jig.
Ralf
Old 19th February 2010, 01:50 PM   #6
AndrewT is online now AndrewT  Scotland
Yes,
and the sharp corners will need hand finishing.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th February 2010, 12:59 PM   #7
rabbitz's Avatar
Ralf
It's no problem with a good jigsaw as you can cut within 0.5mm easily. I use 8mm MDF for the jig and use a 6mm or 8mm bit to do the rebate. I tend to cause more damage to the jig by sanding over the cut a bit to exuberantly.... better left as cut as the router jig guide tends to glide over any anomalies due to the larger radius.
You can use the tweeter mounting holes to locate and hold the jig but generally clamps work well. The jig just has to be large enough so the clamps are away from the router base. Cleats can also be screwed on the underside to lock on the side etc of the enclosure so there is no movement.
A test run on some scrap material is advisable but I generally just get into the enclosure.
You want to try a rebate for a Vifa D26NC with a square heatsink as it's a job from hell.
Here's some rebated HDS drivers and one also has the tweeter rebate done via a jig due to the flat edge on the faceplate.
Old 20th February 2010, 02:04 PM   #8
trd1587's Avatar
Ok Next exercisse is to flush mount 'em!
Old 20th February 2010, 05:17 PM   #9
Thanks guys... This thread had good timing. I am mounting a non round frame from the back with 1/4 rebate to get the tweeter/woofer distance correct for the crossover.
I just ordered a guide bushing set and will go dust of my jig saw.
Old 21st February 2010, 04:52 AM   #10
rabbitz's Avatar
Not sure what you mean but they are rebated so they are flush mounted.... ie in line with the baffle.
Who can cut holes? smellygas Multi-Way 8 2nd August 2009 09:17 PM
What tool to cut baffle holes? kvk Full Range 24 4th April 2008 06:18 PM
8" Drivers for a small U-Frame Tenson Multi-Way 11 7th January 2007 03:27 AM
re-use DCM time frame drivers quiet Multi-Way 3 27th February 2006 04:11 AM
How to cut holes for tubes woody Tubes / Valves 23 23rd December 2004 08:24 PM
Copyright 1999-2017 diyAudio
