How to paint over brushed aluminum? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd February 2010, 02:26 PM   #11
theAnonymous1's Avatar
Originally Posted by bear View Post
....btw, what is the point of making it "black"?
Don't tell me you missed that part?
Originally Posted by nonsub View Post
I expect that such a mod will bring subtle but significant improvements to dynamic range.
Old 4th February 2010, 01:30 AM   #12
MJL21193's Avatar
I took a mounting bracket off, touched to mains and no spark. Scratched it up a bit and did same. Big spark. So it is metal, probably aluminum but coated.
There are safer ways of determining if a part is metal or not. Seriously.
It is aluminum, brushed and lacquer coated.
To paint it lightly scuff it with fine steel wool, clean and spray.
Old 4th February 2010, 02:01 PM   #13
expert in tautology
bear's Avatar
Not likely... but ok.
Might work to take it off with steel wool, might not.
Try it on the back panel or someplace not visible, I guess...
belt sander is a sure bet...??
Otoh, somehow I doubt that black paint on the front panel will effect the dynamic range, subtly or not. Wait... it might... nah.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 4th February 2010, 03:11 PM   #14
I've painted over bare aluminum with spray lacquer before (DEFT). It's been over 3 year now and it looks exactly the same as the day I did it.
Old 4th February 2010, 03:21 PM   #15
trd1587 is offline trd1587  Canada
trd1587's Avatar
I Think you need air plane grade primer
Marc
Old 4th February 2010, 04:04 PM   #16
MJL21193's Avatar
I have a DCX2496, do you? It is a brushed aluminum finish with a thin coat of clear lacquer to stop oxidization. Understand?
The purpose of the steel wool is not to take the lacquer off, it's to prep it for a new coat of paint. Anyone who knows anything about doing this would recognize what I am saying.
Belt sander...
Best to say nothing if the advice you bring is not only useless but also harmful.
Old 4th February 2010, 04:09 PM   #17
Magura is offline Magura  Denmark
Magura's Avatar
Belt sander...
At least it's gone then
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 4th February 2010, 04:37 PM   #18
MJL21193's Avatar
Magura
I expect the next recommendation will be flamethrower:
Make damn well sure that we are down to bare metal, mister!
Old 5th February 2010, 02:18 AM   #19
Anonymous,
I'm interested in possibly painting plain (non-anodized) aluminum ..but only if it's low effort!
My biggest concern is flaking of paint where other metal parts (screws, transformers, etc) come into heavy force contact with the lacquer and the eventual separation of the lacquer from the aluminum. From your pic it appears that you only have non-metal parts in contact with the surface. I guess just try and see but any thoughts?
I can't seem to source DEFT (or any other brand name) spray can black lacquer online. Can anyone point me in the right direction?
Old 5th February 2010, 04:08 AM   #20
Honestly, I think any non-anodized coating will run the risk of chipping anywhere there is forceful contact with another metallic object.
The front of that same chassis in the pic is also painted aluminum. I used self-etching primer and then regular spray paint over it. It has held up perfectly fine, no flaking or anything. It isn't bullet proof though; it can definitely chip if mistreated (especially the sharp edges).
To paint brushed aluminum Duo Everything Else 23 9th October 2007 05:22 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 02:14 AM
brushed aluminum finish, how to? power Everything Else 34 18th October 2004 12:08 PM
Aluminum Paint and pics of my Zen! cmcgraw Pass Labs 13 29th December 2001 01:10 PM
Copyright 1999-2017 diyAudio
