Soldering Panasonic ECG and Similar Tight Pots - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th January 2010, 04:15 PM   #1
DreadPirate's Avatar
Default Soldering Panasonic ECG and Similar Tight Pots
The stereo Panasonic ECG is a real pain to solder onto, six pins, all very tight together. I'm thinking the best way to do this is perhaps soldering on mini pin connectors onto my wires, slipping onto the pin, then tack soldering again. I'd have some shrink ready to slip over the connection when done to prevent inadvertent contact with neighbors. Any techniques out there that might do a better/easier job of this?
Old 9th January 2010, 10:04 PM   #2
mjf is offline mjf  Austria
hello.
i like to do this:
first i solder the cable
and then the pins of the pot
and after this i put the (tiny) cable on the pins with a pair of tweezers and the solder iron finishes the work.
heatshrink looks good.........hand made.
greetings
Old 9th January 2010, 11:06 PM   #3
Originally Posted by mjf View Post
hello.
i like to do this:
greetings
That is how I did it last time and I'm looking for a better way. It has worked, but it was quite painstaking. I also used a magnifying lamp and very sharp soldering iron tip. I like how cheap these Panny's are, but maybe I need to be looking at larger sized pots?
Old 10th January 2010, 04:26 PM   #4
Enzo is offline Enzo  United States
Radio Shack sells a variety of experimenter pc boards, laid out like the little solderless breadboards. Use an Xacto saw or something to cut out a small piece of that. Set the pot legs into a row of holes, and solder wires to the adjacent holes in the row,. You often see this approach in consumer goods - like a lonesome headphones volume control on its own tiny pc board in some tape deck.
Old 10th January 2010, 05:38 PM   #5
BINGO! This is the way to do it, thanks.
Panasonic pots for sale Peter Daniel Swap Meet 15 21st December 2009 12:40 PM
Panasonic ECG caps obsolete, any recommendations? OliverD Parts 0 31st October 2008 11:13 PM
Philips ECG 12AX7WA or GE 5751 ?? Opinions, please. aldovan Tubes / Valves 0 26th January 2007 06:31 PM
fast tight small OB sub inrank Subwoofers 3 31st July 2006 01:19 PM
Panasonic Plastic Pots AKSA Parts 5 9th May 2005 12:32 PM
Copyright 1999-2017 diyAudio
