Help- Screw turning in speaker mounting hole - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 20th December 2009, 06:03 PM   #1
ra7 is offline ra7  United States
Default Help- Screw turning in speaker mounting hole
Hey guys,
I'm having trouble getting out the top two screws from my 8" driver. The screws keep turning in their hole. They don't slide out, and they are not getting screwed in anymore either. They just keep turning.
I've tried turning the cabinet in all directions. Tried ejecting them with helper screwdrivers. Nothing is working.
I had used the hurricane nuts from PE on the back side of the baffle.
Any help is greatly appreciated!
Thanks!
Old 20th December 2009, 06:36 PM   #2
Speakerholic
Cal Weldon's Avatar
Can you pull another driver and get at them that way?
If not, pull the screws you can and use your helper screwdriver on the flange of the driver close to the screw. Pry out so as not to bend the flange but enough to create friction on the nut flange.
planet10 needs your help:
Let's help Ruth and Dave
Old 20th December 2009, 07:23 PM   #3
Thanks Cal! Tried prying it, but I can't get any traction on the hurricane nut. It is rotating with the screw. I have a fairly large opening down in the bottom. This is a folded voight pipe cabinet. I can get my hand through the bottom opening but I can't get it to the nut from the inside.
Old 22nd December 2009, 08:24 AM   #4
Enzo is offline Enzo  United States
Sounds like once you get the speaker out of the way, the bolt would be easy to extract from the rear, if it had no head.
Got Dremel? A carbide cutoff wheel in your Dremel would shave the head off the screw. Grind away the head and pull the speaker off over it. Then pull the nut/screw out the back. If your speaker is OK and to be reused, then apply liberal tape around the screw head to help protect the finish on the speaker flange.
You could chuck a small cutoff wheel into a power drill motor if you lack a Dremel. A lack of Dremel tools is a sure sign of civilization passing you by.
Looking at the pictures, hurricane nuts appear to be like T-nuts without the teeth. If your hole strips, those tiny barbs have nothing to catch. Look up "T-nuts" at PArts Express to compare. For future reference.
Mounting screw terminal capacitors to chassis ssmith Pass Labs 1 6th October 2007 04:25 PM
Noise thru speaker when turning off Dan2 Car Audio 4 4th November 2006 09:46 AM
Vintage speaker screw outs to 1/4" plug JayGee Tubes / Valves 1 6th May 2005 10:45 PM
Speaker Screw Supplier Jye Multi-Way 4 7th October 2003 09:26 PM
What if I screw up a speaker? S.C Chip Amps 28 26th September 2003 02:47 PM
Copyright 1999-2017 diyAudio
