Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 22nd December 2009, 10:35 AM   #11
thank you for your suggestions. I had no problems in the past with cheap RCA jacks (it was very intuitive). I verified on the net that most of the "expensive" connectors are shaped like the Cardas RCA I have, with a slot that I also assume is the place where the ground should be soldered. But I found very difficult to allow for the screwing of the connector cap.
Renato
Old 22nd December 2009, 10:52 AM   #12
just to tell you that a more careful read of the Cardas web site already gives the official answer. Quoting from the Cardas web site:
Q.) Greetings! I just bought 2 meters of Crosslink II interconnect cable and 2 pairs of AGMO RCAs. I just want to inquire how is the proper way of connecting the RCAs to the cable? - Thanks, Ran
A.) Ran, First you must tin the ends of the two Litz conductors. This is best done with a solder pot, but it can work with a very hot solder iron and some patience. Once the wires are tinned on both ends you solder the hot wire to the center pin at each end, then the ground wire to each RCA body at both ends. Last, you solder the shield to the body of the RCA at the source end only.
Some times it's easier to just wrap the shield and the ground wire together at the source end. Cardas RCA plugs tend to need more heat for the solder to flow. The best place to solder the ground is directly under or on the side of the bridge. - Brian
It seems that my problem is that I have not a sufficiently hot solder or... a sufficient patience
thank you again
Renato
Old 22nd December 2009, 04:17 PM   #13
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by Geek View Post
Exchange it for a nice Neutrik instead?
Well, that one you pictured solders like a PL-259 RF connector... you trim and tin the centre conductor and shield, insert, then solder through the slot.
Cheers!
These are very nice, i just ordered many pairs
Old 23rd December 2009, 08:27 AM   #14
just to complete the information; I got an answer from the Cardas support, see the attached picture
Renato
Wire-Wrap vs. Solder phishead8 Equipment & Tools 12 24th May 2011 02:21 PM
simple se ground to speaker wire? pforeman Tubes / Valves 4 27th July 2009 01:13 PM
What does the phono ground wire actually ground? kirk57 Analog Line Level 7 30th May 2008 07:20 PM
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 03:12 PM
TDA2030A success! Dumb Question - how to wire a headphone jack... Morse Headphone Systems 5 27th January 2004 02:43 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
