How to unbend circuit boards? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 1st December 2009, 09:59 PM   #11
DaveG is offline DaveG  United States
I recently flattened an improperly stored software CD. It was smushed in a box in a paper sleeve and had so much warp it would hit the mechanism. Almost 1/8" warp.
I used 2 pieces of glass out of some picture frames, cleaned them well, and set the glass CD sandwich directly on the oven racks, with no additional weight. I prewarmed for an hour on the lowest setting, then took it up to about 200F for 10 minutes and let it cool down for an hour. It took out some of the warp, and did not hurt the silk screen image.
Since it did not appear to hurt anything, and I knew 200F is not really enough, I repeated the same prewarm procedure and took it to 280F, then a long cool down with the oven door closed.
Huge improvment, almost flat, did not hurt the printing and the software installed fine.
Dave
Old 7th December 2009, 02:48 PM   #12
You can bend them cold also.
By the sound of it that's what happened in the post in the first place, so you'd think so
Old 7th December 2009, 04:26 PM   #13
49 - for the 19th time!!!
c2cthomas's Avatar
3.2 Bow and Twist Repair
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Cyro circuit boards DynacoDave Chip Amps 4 25th November 2009 02:06 PM
Pearl circuit boards spuddy42 Pass Labs 5 17th November 2006 08:57 AM
250 Watt FET AMP Circuit Boards auric Swap Meet 1 1st September 2006 07:26 AM
circuit boards/wiring etc ding Solid State 11 25th February 2002 07:34 PM
Zen circuit boards for sale. pixie Pass Labs 0 9th February 2001 04:22 PM
Copyright 1999-2017 diyAudio
