i need about 100amps at 12 volts - Page 5 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 1st December 2009, 11:03 AM   #41
MikeHunt79's Avatar
100amps is going to need thick wires.
A simple solution would be to get a 1500VA trafo, with a 9v secondary windings, then use a full ave bridge rectifier and caps.
Also, if it's a car amp, it may work better from 14 volts instead of 12.
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 03:52 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 01:10 AM
Copyright 1999-2017 diyAudio
