Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th December 2009, 08:23 PM   #61
Steve Dunlap's Avatar
Be sure to check out the link in the link I posted for more tips on tapping. I try to give links whenever possible as it gives credit where it is due. Also I don't have to type so much.
Old 15th December 2009, 03:01 PM   #62
Any suggestions on what I should cover next?
Old 15th December 2009, 07:02 PM   #63
Marinos is offline Marinos  Greece
Marinos's Avatar
Finishing ideas/suggestions.
Anodizing ? Painting ? Simple sanding ?
Marinos
Old 17th December 2009, 08:41 PM   #64
Anodizing isn't the type of thing you DIY normally, but I will talk about some ideas I had on the subject latter.
You can get a very nice finish by sanding with very fine grit sandpaper and a sanding block. I used to wash my Al parts in the dishwasher after sanding. I used TSP, back when it WAS TSP. Make sure you don't have any of those products that prevent spots on dishes. After the dry cycle, inspect the parts. If you have scratches or gouges in the surface, you can try to place them where they won't show. If that isn't possible, then I suggest painting.
First, fill the defects with automotive body filler (Bondo) or JB weld. Since they are scratches, they should already be rough enough to give good adhesion. For dents you may need to rough the surface with course sandpaper. After the filler dries, sand smooth and wash again.
They are making paints now that stick pretty well to Al, and they may work for you. If you have trouble finding a good Al paint, try to find an etching primer made for Al. You can also buy a chromatic acid solution at many large hardware stores. This works quite well on Al as a surface prep. Always read and follow label directions. Rinse with distilled water and dry quickly. As soon as your part is complete dry, paint the part so new oxide does not form.
I have produced very nice finishes using glass beads in a blast cabinet, but that might not be an option for most of you.
If the surfaces of the parts are defect free, you can get a good finish with sanding alone. Each grit of the sandpaper will give a slightly different finish. Pick one you like.
Another finish I like is wire brushed Al. This can be difficult to get a smooth even finish, but if you don't like the finish, you can brush again or sand. A brushed finish can be painted also, but that covers the brushed finish. Different brush wheels give different finishes. You can test on a scrap piece to see if you like the look.
Old 17th December 2009, 08:59 PM   #65
MJL21193's Avatar
Another finishing option on raw aluminum is the frosted look:
and closer:
I did this with a random orbit sander loaded with a 100 grit disk. Holding the sander firmly to the surface prevents it from spinning (and creating swirls).
Once it is as even as you would like, clean with acetone or lacquer thinner and spray on 2-3 coats of lacquer.
Old 17th December 2009, 10:09 PM   #66
I like that. More input from people is welcome. I doubt I have thought of everything.
Old 18th December 2009, 03:22 PM   #67
I should mention that if you use TSP to wash Al pieces, you may not like the look of the finish. This, and things like chromatic acid should only be used on pieces you plan to paint.
Old 18th December 2009, 04:04 PM   #68
400 is offline 400  Germany
while finishing of aluminium and avoiding corrosion, fingerprints etc., I use hard wax for sealing. The surface gets a little bit darker but retains the raw aluminium look.
(What is TSP?)
Marcel
Old 18th December 2009, 04:35 PM   #69
Trisodium phosphate - Wikipedia, the free encyclopedia
Try Trisodium Phosphate For a Thorough Clean Before Painting
TSP Trisodium Phosphate heavy duty cleaner
That should get you off to a good understanding of TSP.
Old 18th December 2009, 04:57 PM   #70
rdf is online now rdf  Canada
rdf's Avatar
Does it result in a long term attractive finish or is some form of sealing required?
Ears aren't microphones.
What case is this? lanierb Class D 2 4th January 2007 10:14 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
case theChris Parts 2 8th February 2003 08:08 PM
How to build a swell case...??? pipetman Parts 2 4th October 2002 12:22 AM
Page generated in 0.10941 seconds (80.08% PHP - 19.92% MySQL) with 11 queries
