Build your own case Build your own case - Page 5 - diyAudio
Construction Tips Construction techniques and tips
Build your own case
Build your own case
Old 25th November 2009, 07:11 PM   #41
Steve Dunlap is offline Steve Dunlap  United States
Steve Dunlap's Avatar
Here is a more detailed example of a side panel. I haven't given dimensions for the holes. You will select that based on the hardware you choose. I have left gaps at the coroners just as you may have in real life. The size of the gap will be determined by your skill at measuring and cutting. The example here is using 0.125" thickness for all stock. The second file is the same with a different perspective.
Old 25th November 2009, 07:15 PM   #42
Magura is offline Magura  Denmark
Magura's Avatar
Steve,
This tutorial is getting real nice.
Good work.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 25th November 2009, 08:20 PM   #43
Originally Posted by Magura View Post
Steve,
Good work.
Magura
Thank you. Now on to some details of actually building a case.
Step 1: Decide what you need or want in the way of size.
Step 2: Sketch out all the parts you will have. For a case like we are discussing, you will have a top, bottom, two sides, back panel and a front panel. Give the panels dimensions. You will also have 12 pieces of angle to tie everything together.
Step 3: Decide how thick you must have or want to have for the flat panels. The sides will be the same thickness, but the rest of the pieces can be different. The bottom may need to be thicker (depending on what you choose for the sides) to support heavy objects like transformers. There is no rule that says all the flat pieces must be the same thickness. You may find that the top can be thinner stock than the bottom. The same is true for the back. The front will often be a cosmetic choice.
Step 4: If possible, make a cardboard model of your project to look for problems with sizing or interference between parts.
Step 5: Decide if you want to cut the angles yourself. Order the metal.
Step 6: When the metal arrives, check for size or defects. If you are cutting your own angels, do that first. If you don't have a band saw, there are other options. Google "cutting aluminum". If none of the other options are available to you, you can use a hacksaw and a miter box. Clamp the box to a solid surface and clamp the angel to the box.
Step 7: Do a test fitting with clamps. If the parts are cut correctly, it's time to start laying out the holes. Start with the four angels that will mount to the bottom. Using a combination square, mark the positions of the holes as closely as possible. Use an awl or an Exacto knife point to to make the marks so they will be more exact. Center punch the marked holes. Now you have a decision to make. The only place you really need threaded holes is where you can't reach the inside of the case, like when you put on the top. The rest of the holes can be drilled for machine screws of your choice using lock washers and nuts. If you want to thread the holes, that is your choice. After you drill an angel, clamp it to the panel where it will be fastened, line it up correctly and tighten the clamps. Now drill the panel through the holes in the angel so they will align perfectly. These pieces can be clamped first then drilled if you are shure you have the holes laid out correctly.
Step 8: If you are using flat sides you can repeat the steps above. If you are mounting heat sinks for the sides, you do pretty much the same thing using the heat sink instead of the flat panel. I have attached a drawing of a mounted heat sink. Doing it this way eliminates the need to cut out holes in the sides.
More latter.
Old 27th November 2009, 08:24 PM   #44
Here is a drawing of the bottom with the bottom angles in place. Here I have used the square construction as it is both easier and there is less scrap. You will notice I have left a gap of 0.062" between the angle pieces to ensure clearance. You can reduce that gap if your cutting is very exact.
You will also notice that the bottom is 0.25" smaller than the case size of 12" X 17" X 3". This is so the completed case will be the correct size. This is based on 0.125" thickness sides, front and back. You may use other thickness material, just adjust the sizes accordingly.
As I mentioned earlier, you can drill the appropriate size holes for your chosen hardware. If you choose your hardware too large, you will need to move the holes further from the edges so the nuts have room to fit inside. Many times more than one size nut is offered for a given screw size, so you may be able to use one with smaller outer dimensions. I recommend lock washers also.
Old 29th November 2009, 09:43 PM   #45
I suggested that you should sketch the case before you do anything else. I should follow my own advice. After drawing the rest of the parts, I realized that there was a mistake in the drawing of the bottom. Here is the corrected drawing.
Old 29th November 2009, 09:56 PM   #46
Here is the drawing of the side, back and top. I Zipped the top because the file was too large. If you have questions about why I have done anything the way I have, please ask. I probably had a reason, but it could be another mistake on my part.
I will give pointers for making holes and adding vents next, then move on to making your own heat sinks.
If I am leaving out something of interest to you, please ask about it.
Old 1st December 2009, 06:33 PM   #47
In a typical preamp almost all of the holes are, or can be, round. They can be made by careful measurement, center punching and drilling. For larger round holes, the step bits work nicely. Another way I have laid out the hole patterns for the back of a preamp is to draw the back, from the inside view in a cad program, then print it. Draw the inside edges also and be sure to mark the hole centers. Now trim along the edge lines (I used a paper cutter) and tape the drawing to the inside of the back panel. You then use a center punch to mark all the round holes.
Enco - Guaranteed Lowest Prices on Machinery, Measuring Tools, Cutting Tools and Shop Supplies
Drilling works on many of the holes in an amp case also. There is no substitute for punching when it comes to the D shaped holes that many binding posts use. This is complicated even more by the fact that there is no standard hole sizes for input and output hardware. Fortunately, all of these can mount in round holes.
Ventilation holes for amps is another problem, but there is an answer for these also. Holes for fans can be cut using this tool.
I have one of these that cuts up to 6.5" holes. It works great for small speaker mounting holes also.
For tube equipment or amps with internal heat sinks where fan cooling may be considered too noisy, there is an assortment of perforated Al sheets available in 0.062" and 0.125" thicknesses. The entire top could be made with this material, or you could make the top (or bottom) from more than one piece mixing solid plate and perforated plate to suit your needs.
Perhaps the hardest hole to make in a case is the IEC power inlet. There are many variations on this and some take different size holes. The solution here is to have what you plan to use on hand and measure it. I suggest drilling four holes of the same radius as the rounded corners of the inlet, inset by the same radius. This gives you the four rounded corners in the correct location. Now use a metal cutting in a jig saw to finish cutting the hole. There are other options also. See the link I posted earlier about cutting square holes in Al.
Any questions or comments so far?
Old 1st December 2009, 07:20 PM   #48
Here is the BOM and price (less shipping) for the case.
Old 1st December 2009, 07:50 PM   #49
Here is an example of a DIY heat sink. Drill the correct size hole for the tap you will be using through both the flat sheet and the rectangular extrusion while they are clamped together and aliened properly. Unclamp and drill the correct size holes in the flat plate. Tap the holes in the extrusion. You can also use machine screws and nuts if you prefer.
Old 2nd December 2009, 09:59 AM   #50
Marinos is offline Marinos  Greece
Marinos's Avatar
Hi Steve,
In the heatsink zip there are links to pdfs but not the actual pdfs (BOM and pricing is ok though).
Congratulations for this usefull thread.
Marinos
Build your own caseHide this!Advertise here!
What case is this? lanierb Class D 2 4th January 2007 10:14 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
case theChris Parts 2 8th February 2003 08:08 PM
How to build a swell case...??? pipetman Parts 2 4th October 2002 12:22 AM
Copyright ©1999-2017 diyAudio
