Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 12th November 2009, 09:24 PM   #1
Jimmy154's Avatar
Default Drilled some holes crooked; what's a good filler?
Hello friends,
I drilled some holes crooked and I'm wondering what can I fill them with so I can drill new holes with a drill press, this time
Wood putty/filler won't work; it's too brittle and has no structural strength. I was thinking maybe there was some sort of two part epoxy I could use for this purpose or wood glue and saw dust mix?
We do not allow political statements or conjecture to be made on these forums.---the diyAudio moderation team
Old 12th November 2009, 09:38 PM   #2
wrenchone's Avatar
Try JB Weld, available in hardware and automotive stores. It takes 24 hr to cure, but it's tough as nails.
Old 12th November 2009, 09:40 PM   #3
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Liquid Steel, but it's expensive.
Zen, BOZ, BOZ-J, BLS, B1, Mini-A, Audio Sector NOS DAC, Gain Clone, F5, CAT5 Speaker Cable, DIY Allen Wright ICs, MOX II
Old 12th November 2009, 10:12 PM   #4
MJL21193's Avatar
Vote #2 for JB Weld - amazing stuff.
Old 13th November 2009, 12:16 AM   #5
What are you working with?
Is it metal or wood?
How are these holes being used?
Can you just use a larger drill to clean up the out of line hole. . .larger drill being used in a drill press that is.
Old 13th November 2009, 12:25 AM   #6
Jimmy154's Avatar
Funny I just used some of this stuff to fix my car. I thought it was mostly used for metal. It would not be such a good thing if it was a lot harder than MDF. I have to be able to drill through it again and the MDF. The new holes will mostly be through the fixed part also through the MDF.
I should have done it right the first time
Old 13th November 2009, 12:27 AM   #7
nigelwright7557's Avatar
Fibre glass will go rock hard.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 13th November 2009, 12:36 AM   #8
MJL21193's Avatar
You didn't mention it was MDF...did ya?
Automotive body filler would be a better choice on MDF - you know, Bondo?
Old 13th November 2009, 05:27 AM   #9
use West System #105 epoxy with #205 hardener and mix with #404 High Strength Filler. Use #206 hardener if you want a longer cure time. You can cast a threaded hole with this stuff by spraying the fastener you want to use with WD-40 or even cooking spray for a release agent, wiping off the excess, and then sticking it in the epoxy/filler mixture and letting it cure. You'll need some sort of jig to hold the fastener in the proper alignment of course. This trick came in handy more than once when I used to own a boat.
West System products available at your local marine store.
Old 27th November 2009, 11:51 PM   #10
soundchaser001's Avatar
#3 for JB Weld.
Used it to fill a duff hole in an armboard for an Ariston RD-11S which I subsequently re-drilled for an RB300. The hole intersected the original material (some kind of plastic) and the JB Weld. It was flawless. Before use the armboard was tapped, dropped and otherwise abused albeit gently to see if the weld piece would come loose. Not even close.
Some might say that CTE mismatch could be a problem but if it's an indoor domestic application it won't be.
Good luck
Matt
Need a filler Mid. Suggestions? K-amps Multi-Way 10 9th November 2006 04:12 AM
Is Rotozip a good tool for cutting holes? AJ Bertelson Multi-Way 10 9th June 2004 08:36 PM
To cover the drilled holes on mdf? Tony.ca Multi-Way 16 20th April 2004 04:43 PM
help...drilled hole too big ultrachrome Parts 16 15th April 2003 05:07 PM
Page generated in 0.12377 seconds (78.76% PHP - 21.24% MySQL) with 10 queries
