| Construction Tips Construction techniques and tips |
#11 |
Depends on the chip though. I think the best option for him would be a Tripath TK2050 based design. Probably beats any discrete or chipamp design, no matter what money you throw at it too.
#12 |
Did it Himself
Yes, to get more power out of a low voltage, a car 12V battery. Essentially the same issue as what this guy has.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#13 | |
High volume requires efficient speakers - This may be possible with a limited bandwidth of frequencies. |
#14 |
#15 |
The Eminence Alpha-6C is a fairly high efficiency 4 Ohm midrange. It's also fairly flat and maybe tolerable sounding. But it is not efficient enough for 115dB from split 15 volt supplies.
#16 |
Will that run from +-15 Volts? I thought he had a required supply limitation for some reason.
#17 | ||
But horn designs is a far better option, for example the DR250 (http://www.billfitzmaurice.com/DR250.html) will have 105dB/w/m with a fairly standard 10" PA driver. Only takes 10 Watts to get that to produce 115dB at 1m ... or roughly 90 Watts for 115dB at 10 feet. Build the version with 2 10" PA drivers and 115dB at 10 feet is easily within reach on the afore mentioned amplifier on a 30V supply. Last edited by Saturnus; 16th November 2009 at 09:02 PM. |
#18 | |
OOOps . excuse me !! Got mixed up with detectable increase of sound level by the human ear , which is 2db
#19 |
| about making amplifier | mehtadhaval | Chip Amps | 4 | 14th April 2008 08:50 AM |
| Making my 1st AMP! (40/60w Bass Amplifier) | Shakal | Solid State | 19 | 12th June 2007 04:36 AM |
| Making a sub louder using electronic filters e.t.c | bob123 | Subwoofers | 10 | 18th April 2006 08:08 AM |
| Anyone actually suceeded in making a car amplifier? | SkinnyBoy | Car Audio | 34 | 30th December 2003 03:28 PM |
| Amplifier Making Suggestion | debipilu | Introductions | 5 | 3rd January 2003 04:01 AM |
| Page generated in 0.11362 seconds (78.70% PHP - 21.30% MySQL) with 10 queries |
