| Construction Tips Construction techniques and tips |
#31 |
Laser? EDM? CNC mill?
I usually mark it out, drill near the corners, and file, file, file. Nice job when I'm done, but there's GOT to be a better way. Takes forever and calls for a lot of patience. Out of all the things that are done by drilling/filing, the IEC 320 mains connector thing turns out to be the most difficult for some reason. For larger rectangular holes, I drill near the corners and use a sabre saw with the finest blade obtainable, going very slowly, giving the edges a wide berth and taking care not to mar the finish (if BOTH sides have to be finished, this is a BAD IDEA!). In any case, this requires great care to avoid marring the surface with the saw's sole plate. Beats anything else I've tried for larger holes, (6-8" square or larger) For smaller square holes (1/2"), I just drill the largest hole I can and file the edges square. I'll admit to sometimes drilling a series of close-spaced holes (3/16 or 1/4), using dikes or a fire-ax or something to break the "web" between holes, then file, file, file. Good for odd-shaped holes of medium size, say 2-3" -or narrow slots. Have bandages handy. Nibbling tools- I have to really consider if there might be a better alternative- and there usually is. They tend to mar the surface about 1/8" on either side of the slot they cut. Still need to file or otherwise finish. And for VERY large holes, my hands give out before the slot is cut. I generally agree- these instruments of torture offer only false hope, and should be banned. A set of high-quality, perfectly clean and SHARP files is invaluable. |
#32 |
Buy an IEC extension cable: the male end accepts the female end of a regular IEC cable. Cut the end and connect it to the amp via a round hole and grommet. I'm not sure what makes an IEC connection so desirable - all my pro amps have little pig tail sort of cords on them, like a toaster. I don't se what's wrong with that approach for DIY too.
#33 |
From now on: EDM. My brother owns two Agiecut 100 wire EDMs. This technology is absolutely "the ****" when it comes to cutting non-circular holes in sheet metal...or in 10" thick blocks of hardened steel for that matter.
#34 |
Here is something that will make the filing easier. Put pieces of wood on both sides of the panel and clamp them in place with a couple of C clamps. Make sure the wood edges are lined up on your target line. Then file away.
Putting these pieces on either side of the panel makes the panel stiffer and makes the filing much faster. They also serve as guides to keep you filing flat and to tell you when to quit. Dr. Spiff |
#35 |
I dont know if its been mentioned
But files fore alu are made with a very special "cut" They really are way more effective than ordinary ones Especially if a lot of material is to be removed, or fore massive alu Fore the last finer work, ordinary files are ok Fore thin alu sheet I have also used a slim(5-10mm) and very sharp carpenters chissel, and a hammer and its important to remember hardwood as backing, or it will bendWhat I find the hardest is to avoid scratching the surface |
| Who can cut holes? | smellygas | Multi-Way | 8 | 2nd August 2009 09:17 PM |
| Holes in braces? | screamersusa | Subwoofers | 2 | 29th December 2008 02:12 PM |
| Cutting holes in aluminium enclosures | emperor | Parts | 4 | 22nd July 2007 08:45 AM |
| making rectangular holes in aluminium case | AdamZuf | Everything Else | 7 | 23rd November 2006 04:39 PM |
| How to cut holes for tubes | woody | Tubes / Valves | 23 | 23rd December 2004 08:24 PM |
| Page generated in 0.10730 seconds (76.76% PHP - 23.24% MySQL) with 11 queries |
