| Construction Tips Construction techniques and tips |
#11 |
Look at Digikey (for example) and enter "Silpad" in the search box.
That is a brand name for a silicone insulator, made by Bergquist For example the TO247 one ought to fit your larger transistor: Digi-Key - BER178-ND (Manufacturer - SP900S-104) Their part number BER178 if my link doesn't work |
#12 |
Those work very well, I've used them for years. As a bonus heat sink compound is not required with them so they are much less messy.
#13 |
If you have hard anodized sinks you may not need anything more than thermal grease and isolated mounting. This has worked well for some manufacturers in the past, and creates a minimum thermal resistance interface.
#14 |
yes.... it may be cheap.... but finding them????
#15 |
#16 |
I say look on ebay, or buy from the suggested places, why build something that will just blow up, then you will be replacing the transistors that you burnt up.
What about buying the iso pad's from the source that you got the transistors from ? J' |
#17 |
I can second that you should not use regular Arctic Silver 5 - I tried it and sent about 180 volts through it around the mica.
I am comfortable with mica/white grease or silpads - I have used thermasil brand with good results. |
#18 |
Kapton tape works well. Just keep all the sufaces clean and smooth since it punctures easily.
#19 |
Can anybody explain the pro's and con's of using silica pads over mica washers and thermal grease? Should you use thermal grease with silica pads? I have always used mica insulators with grease but latrly I have noticed pads being used and it looks like no grease. So the pads don't need grease?
Richard Jenkins |
#20 |
The silica pads are easier to use but at least the comon ones don't transfer heat
as well as the mica. There are much more expensive silica pad type ones in the $1 each price range that do transfer heat a lot better but for a price performance standpoint mica is still hard tobeat. |
| Heat Sink / Fan Deal | I_Forgot | Chip Amps | 0 | 3rd May 2007 11:59 PM |
| heat sink for UCD700? | pburke | Class D | 68 | 7th July 2006 05:40 AM |
| Yet another heat sink problem | OliverD | Pass Labs | 10 | 16th October 2003 06:29 AM |
| How much heat sink is necessary? | rosss | Pass Labs | 11 | 23rd February 2003 06:23 AM |
| Page generated in 0.11476 seconds (75.05% PHP - 24.95% MySQL) with 10 queries |
