Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 6th November 2009, 09:58 PM   #1
audi0 is offline audi0  Australia
audi0's Avatar
Default Enclosure construction
I was looking for suitable enclosures for a couple of projects that I was working on, I needed four of different sizes, the commercially made ones that I had short-listed were a bit too much for the available budget, so I got thinking how I could build something like I wanted myself, I ended up with some readily available off the shelf extrusions and AutoCAD and came up with this:
The Concept
Old 6th November 2009, 10:09 PM   #2
audi0's Avatar
Default Construction
Early stages of manufacture, the extrusions are cut, the back and face plates I used are 3mm thick as that's all I had laying around, you could make these more chunky if required
The fixing holes are drilled and tapped
Old 6th November 2009, 10:12 PM   #3
audi0's Avatar
Default Construction continued
The routing jig for the front panel holes and holes in face and back plates being drilled
Old 6th November 2009, 10:14 PM   #4
audi0's Avatar
Default The cover plates completed
Plates are finished with coarse sandpaper to give a 'linish finish'
Old 8th November 2009, 07:54 PM   #5
audi0's Avatar
Default Small box
The small box shown here is for a Rod Elliott RIAA pre-amplifier, the circuit board complete ready for standoffs and wiring.
This box is ~100mm (4”) square x 50mm high
The length of the outer casings are purposely made longer than the width of the inner channel chassis so that when you tighten the screws, it clamps together. The inner channel chassis is the same extrusion as the case, with one side sawn off.
Old 8th November 2009, 08:00 PM   #6
audi0's Avatar
Default Bit more progress
These are the other three;
1. An old project of mine an Elektor Class A headphone amp that I build many moons ago, (circa 1983!) its a perfect fit in the new chassis, note the tags left on the back to heatsink the output transistors and the large hole in the faceplate to recess the control knob. I plan some hidden LED's in there to light up around the knob
2. Is a Tripath amp board sitting in its new chassis, the board is missing a few parts while it's being upgraded.
3. ls a passive pre-amp / input selector, I plan a Lightspeed Attenuator for this one!
The plan is to get the main bodies powdercoated (don't know what colour yet) and fix the backs and faces with some M4 stainless steel socket head cap screws
I'll post more pictures as the project progresses
Old 8th November 2009, 09:07 PM   #7
just another
wintermute's Avatar
Very Nice work Audio0 Where did you get the extrusions? and roughly how much were they? I'm going to need a case for my B1 (once I get some momentum on it).
Tony.
Any intelligence I may appear to have is purely artificial
Some of my photos
Old 8th November 2009, 11:25 PM   #8
audi0's Avatar
Default Aluminium supply
Hi Tony,
The extrusions, 150 x 50 x 3mm and 100 x 50 x 3mm I bought from a local alloy supplier (Capral) The 150 x 50 x 3 was about A$25/M and the smaller one, 100 x 50 x 3 was about A$18/M
The 3mm sheet I had laying around, I think you would pay about A$40/M² for 3mm sheet
Although I planned to use nutserts, I just drilled and tapped the extrusion instead.
Hope this helps.
Cheers.. Steve
Old 9th November 2009, 04:32 AM   #9
planet10's Avatar
Well done Steve. Your boxes have the same configuration as the NAIM NAIT I & II that i once owned.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th November 2009, 05:20 AM   #10
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Clean and nice, when is production going ? :P
Switching car audio enclosure to home enclosure wattz Subwoofers 10 18th April 2010 06:51 PM
Linkwitz Orion Construction Kit +assembled ASP+Enclosure + Universal Power Supply FS wagnju Swap Meet 2 29th January 2009 09:35 PM
Enclosure Construction Analysis elambert Multi-Way 5 28th January 2007 06:42 PM
Construction Techniques(putting DIY in a proper enclosure) TomWaits Solid State 38 23rd May 2006 03:20 AM
Page generated in 0.10820 seconds (78.64% PHP - 21.36% MySQL) with 11 queries
