diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Construction Tips (http://www.diyaudio.com/forums/construction-tips/)
-   -   Wiring up Slide Potentiometers / Faders (http://www.diyaudio.com/forums/construction-tips/153416-wiring-slide-potentiometers-faders.html)
CuttaBoi 15th October 2009 11:56 PM
Hey all, new to the forum, hoping you can help.
Im going to be modifying my VCI 100 (Midi controller) By adding two new faders to it, the faders I've ordered are:
PTE60-151B-103B2 Bourns Slide Potentiometers
The main question I have is will I have to mount these to a pcb board, or can I solder wire to the connection (hoping I can)?
Any help would be much apprecaited.
Cheers
Cutta
T in AZ 16th October 2009 02:42 AM
You can do either, they were made for a board, but you should be good at soldering if you are going to use wire connect.
CuttaBoi 16th October 2009 01:06 PM
Hi thanks for the reply,
I'm not the greatest (But practicing). Do you know if it is possible to buy pcb board's for these to connect to?
cheers
Cutta
T in AZ 17th October 2009 02:10 AM
It would probable be more trouble then it's worth, keep practicing and use heat shrink on the solder connections
CuttaBoi 17th October 2009 11:53 AM
Thanks for the advice, will do that.
Resources saved on this page: MySQL 18.75%
