| Construction Tips Construction techniques and tips |
#11 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I have a wood for you! This stuff is called Quebracho(SP?) It is an extremely high density tight grained wood that was once used in the manufacture of tannin. It is only found down here....it is used for firewood here for its high density & burning properties. You can allways tell if your working with this stuff as nails will penetrate only about 1/4"....& bend on you, it cannot be worked with hand tools and it weighs a ton! . It is used for railroad ties and fenceposts here for its resistance to the elements. It has a graining that rivals the likes of Walnut.
Wouldn't you know it, it is a slow growing wood that is being overharvested. __________________________________________________ _____Rick.......... |
#12 |
I'm somewhat partial to using a mix of play sand and lead shot, if you want to make them portable, just provide for an easy way to empty them into a container. Otherwise, concrete would be my choice and it's cheaper as well!
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#13 | |
Steve
#14 |
Build a box with an open bottom the size and shape you like. People here are saying to fill the box with sand or concrete but an easier way to add mass is to go to the sporting goods store and buy a weight, the kind weight lifters attach to free weights. These come with a convenient hole drilled in the center. Attach the weight to the under side of the box with a bolt and washer.
Iron is more dense than concrete and cheaper than lead, plus that big hole in center makes it easy to mount to the underside of anything with just one bolt. Last edited by ChrisA; 7th October 2009 at 06:23 PM. |
#15 |
See, the problem is I can't have a very wide face (front width), so to get sufficient stiffness I think I might have to make it solid.
Also, to those proposing sand or lead shot: I'm going to drill holes through it, and the holes may not always be plugged.
Building a 2.1 system out of a 3/4"x4'x8' sheet Last edited by 454Casull; 10th October 2009 at 06:49 AM. |
#16 |
...truth seeker...
454,
If you cast it you can embed suitable anchors in it, and/or provide openings for the passage of cables...
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
| FS: Large inductors, Large Ports, and Leaky Holes | luvdunhill | Swap Meet | 10 | 6th March 2009 03:01 PM |
| FS: AD1862 - 4 pieces | Clutz | Parts | 0 | 27th May 2008 06:10 AM |
| Large Cone/large VC or several medium sized cones / medium VCs | vajolet | Multi-Way | 14 | 3rd December 2007 06:10 PM |
| Acquiring a cab | hendrixrocks | Everything Else | 3 | 25th July 2006 02:22 AM |
| large-radius edge pieces for baffles? | Bill F. | Multi-Way | 7 | 23rd February 2005 02:53 PM |
| Page generated in 0.08196 seconds (86.38% PHP - 13.62% MySQL) with 10 queries |
