Construction Tips Construction techniques and tips
Has anyone used 'inward tension' using line/rope/long bolts to stiffen a cabinet?
Old 14th October 2009, 03:07 AM   #21
Spalls is offline Spalls  United States
A simple way to do this is to cut an internal brace piece that spans between opposite panels just slightly shorter than it needs to be (about 1/16 of an inch or so). Position a clamp on the opposing panels and put high quality adhesive on the ends of your brace piece and clamp the sides down to snug the brace. Works for me. It does not take much to put a panel in tension. If you are painting the enclosures rather than using nice wood you can also countersink a screw through each panel into the end of the internal brace to help hold things together if you like. Fill the screw head hole with filler, sand, and you're ready to finish.
Has anyone used 'inward tension' using line/rope/long bolts to stiffen a cabinet?Hide this!Advertise here!
Mortite/Rope Caulk for Cabinet Deadening sdclc126 Multi-Way 37 8th June 2006 11:38 PM
long cable line drive navin Tubes / Valves 40 29th December 2005 03:29 PM
Line array dilemma for 7.1 HT (Long) exipnos Multi-Way 29 17th May 2005 10:23 PM
Line Array Ruminations and Questions (long) cytokine Multi-Way 28 21st October 2004 12:13 AM
My long tought out cabinet project... ergo Multi-Way 9 11th February 2003 05:41 PM
