Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd October 2009, 02:33 PM   #31
MJL21193's Avatar
Originally Posted by zeonrider View Post
Believe or not The best Tool.
Don't use with hand machine, only with Drill Press!
If you are uncomfortable using it in a hand drill that's fine, for you.
Step drills are used everyday in hand drills - I use them every day in a hand drill.
Old 3rd October 2009, 04:48 PM   #32
zeonrider's Avatar
Default Hi!
Safety first!
Regards zeoN_Rider
Old 3rd October 2009, 05:30 PM   #33
MJL21193's Avatar
Safety first!
Regards zeoN_Rider
The safest thing to do is to do nothing...
Believe me, using a step drill in a hand held drill is safe.
Old 3rd October 2009, 05:52 PM   #34
zeonrider's Avatar
Default Hi!
And what about sex
Regards zeoN_Rider
Old 3rd October 2009, 09:35 PM   #35
Geek's Avatar
I could probably tell the difference
As I'm sure any reasonably competent machinist could...
Canadian Tire sells mostly junk now, not much better than a dollar store but they have varying quality.
As for the dollar stores, I don't go to them and I certainly wouldn't buy any kind of tool in there...
Would you be surprised to know I found the same manufacturer stamp on a "Power Fist", "Mastercraft" and a "Craftsman" planer and drill press cast housing?
They all come out of the same Chinese facory
So why not go for the best bang for the buck?
(Yeah, I know they aren't good brands, but for prototyping and occasional custom builds, it's all I need)
I have three qualities of bits on hand I've found optimum for my prototyping work:
- A set of top notch HSS for wood/plastic.
- A set of where-I-can-get-'em-cheap Titaniums for aluminum chassis.
- A set of cobalts for steel/thick aluminum.
As for the hand/press issue, it's all up to one thing - experience.
Cheers!
Old 5th October 2009, 09:49 PM   #36
Jaac is offline Jaac  Netherlands
Jaac's Avatar
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 6th October 2009, 12:57 AM   #37
Originally Posted by Geek View Post
Unless you have cobalt bits and a drill press... then steel drilling is OK
(I have scars on my hand that say WHY you do NOT use a hand drill when drilling steel)
Steel Hammond/Bud/etc. chassis... titanium coated are OK, but do use the cheap ones, cause the expensive ones will wear out just as fast as the cheap ones and you don't feel as guilty when you dump them in the bin
Cheers!
I would like to revise my list and add laser cutting to the top.
Old 6th October 2009, 01:07 AM   #38
zeonrider's Avatar
I too: Water Jet, but not DIY.
Regards zeoN_Rider
Old 6th October 2009, 04:46 AM   #39
Geek's Avatar
Another way to put holes in the appendages
There's a fellow on the Dutchforce electronic forums using one of them things to blast holes in various substances around his shop. I suppose when the novelty wears off, it'll get used on real chassis
Cheers!
FS: Large inductors, Large Ports, and Leaky Holes luvdunhill Swap Meet 10 6th March 2009 04:01 PM
drilling transformer mounting holes-bit broke! ThSpeakerDude88 Everything Else 5 27th October 2007 04:36 AM
Drilling a PCB KP11520 Everything Else 34 12th September 2007 01:28 AM
TO-3 Drilling Jig BrianDonegan Solid State 10 16th February 2005 10:06 PM
drilling holes in chassis Raj1 Pass Labs 6 3rd January 2003 07:56 PM
Page generated in 0.09854 seconds (87.51% PHP - 12.49% MySQL) with 10 queries
