| Construction Tips Construction techniques and tips |
I'm working on a PC based source component of sorts and I'm at a point where I need to put it in a chassis. I'm going to get the front panel from Front Panel Express. It's a basic front panel consisting of about a dozen buttons (monentary SPST) and a small LCD display from Matrix Orbital.
I'm struggling with the buttons. Looking at this picture here: http://www.briangt.com/gallery/cdpro2/cdp02 The actual button cover that you press to activate the switch on the PCB behind the front panel - they're just little pieces of plastic or aluminum with a ridge around the edge so they stay in. Is there a term for those? Where do you get them? I'd like some aluminum ones I could find some. |
#2 |
You can try here, these are my favorite- high quality but also high price.
NKK Illuminated pusbutton NKK Pusbutton However, the switches you are asking about in the picture I think are just metal pieces with a spring behind them. When you push them they actuate a membrane or other switch that is on a PCB behind the front panel.
My DIY audio projects- PartTimeProjects.com. |
#3 |
Are they tactile switches behind the front panel?
If so I believe they are known as "switch caps" Only ever seen cheap plastic ones never seen aluminum ones. switch caps I had the same problem when building my cd player. In the end I layered acrylic to create a button. cd player If you want aluminum ones (which is also what I originally wanted and still do) I would find someone with a center lathe. I do know some one who could do it but I'm sure there must be someone more local to you. |
#4 |
There are couple of other things that can be used ...
Shiny rivets are suitable candidates here as shown below : ![]() keep broad side outwards(push side) inside add washers and strong glue,then they will not come out. you get aluminum ones also ...every where
~AUDIO IS .. FEELING ....THE WAY U LOVE THE SOUNDS TO SOUND |
| Arcam CD73: front pannel buttons inoperative | sdstarnes | Digital Source | 0 | 6th January 2008 10:33 PM |
| Front Panel / Enclosure Help | tumler | Parts | 8 | 7th August 2007 09:41 AM |
| Front Panel Manufacture | Bonsai | Parts | 5 | 21st December 2006 04:01 AM |
| DIY Front Panel !! | udip | Solid State | 12 | 16th January 2005 07:37 AM |
| Aluminium for front panel | jouch | Solid State | 7 | 15th March 2001 11:51 PM |
| Page generated in 0.07988 seconds (72.95% PHP - 27.05% MySQL) with 10 queries |
