Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 22nd August 2009, 10:22 PM   #1
neazoi is offline neazoi  Greece
Default 1.8KHz low pass filter
Hello I need a schematic of a 1.8KHz low pass audio filter. I need it to be as sharp as possible.
Any schematics or links yould be appreciated.
Great DIY site: http://www.neazoi.com
Old 23rd August 2009, 10:50 AM   #2
mjf is offline mjf  Austria
[QUOTE=neazoi;1905023]Hello I need a schematic of a 1.8KHz low pass audio filter.
hello.
i presume you want to use it in a preamp or so.......
there is a schematic of an active third order butterworth filter.
you can use two filters in series if one is not sharp enough.......
example: with r= 10k and f= 1800hz
you will get around 12nf, 33nf and 2nf for c1,c2,c3..........
greetings............
Old 23rd August 2009, 01:27 PM   #3
Yes, it is for audio use in preamplifier levels.
It is basically used in a direct down conversion ssb receivers, to cut off the unwanted sideband of the downconverted (to audio) rf signal.
So this has to be as sharp as possible, to ensure that the higher audio frequencies will be attenuated as much as possible.
I did an extended search in the internet for a program to design such filters and I found FilterLab from Microchip company (the one that produces the PC microcontrollers).
I believe it is very nice program but I need your opinion.
I managed to design a filter using this software and I present you the results here to notify me if it is a sharp filter I have designed or not.
Note, I have no idea what phase slope means, but the responce slope seems sharp enough?
Old 23rd August 2009, 01:30 PM   #4
here are the attachments
Old 24th August 2009, 05:39 PM   #5
that roll off with aripple then fast slope flattening out slightly at higher frequencies looks like a Chebychev.
http://en.wikipedia.org/wiki/Chebyshev_filter
Try Googling for more info.
regards Andrew T.
Old 24th August 2009, 05:51 PM   #6
yes it is a Chebychev filter indeed. I found it to have sharper cut off and the price you pay is about 1db ripple in the passband (with my attatched design).
I really cannot believe how simple it is to design an audio filter using filterlab, is it really so simple or have I done something wrong?
The way to test it can be done with a computer running an audio generator program and another computer testing the filter...
need help with low pass filter prezden Multi-Way 11 12th January 2009 09:04 AM
low pass filter AudioAddicted Car Audio 17 2nd November 2006 07:44 AM
Low pass filter help ifrythings Subwoofers 1 24th February 2006 10:45 AM
low pass filter crazyant Car Audio 3 15th September 2005 07:15 PM
D1 DAC from Pass 20 KHz filter? promitheus Digital Source 2 15th September 2003 06:22 PM
Page generated in 0.10703 seconds (74.65% PHP - 25.35% MySQL) with 11 queries
