Construction Tips Construction techniques and tips
Wood & Varnish
Wood & Varnish
Old 29th August 2008, 08:06 PM   #31
EmergencyDpt is offline EmergencyDpt  United States
EmergencyDpt's Avatar
Send a message via Yahoo to EmergencyDpt
I've stumbled on a bit of cool thing. I don't know if it's helpful or not. However Minwax has a product called 'Sanding Sealer' and it is used over hardwood floors in between the stain and the polycoat. It seeps in very shallow very very shallow and hardens the fibers of the wood like...superglue or something. I used it on a very thin mdf backer board to stiffen it up so I can use it as a sled for my table saw. It seals, penetrates and gets rock hard. I'll bet you could use it on a speaker cone to stiffen it up. I might try that experiment with some of the old speaker's I have lying around.
I also plan on putting it on the inside of my speakers to harden up the plywood. I think if nothing else it will make a unified front for soundwaves and even out whatever response the cabinet generates.
It's totally clear and has a slight gloss when dry. Pretty thin, like nectar thin as we say in healthcare. Thinner than paint or honey for sure.
Don't eat mud, if you can help it.
www.EmergencyDpt.com
Old 29th August 2008, 08:09 PM   #32
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Wood & Varnish
You are using it all wrong. Sanding sealer goes on the bare wood before the stain. It "seals" the pores so that the stain coat is more uniform in colour.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 29th August 2008, 08:30 PM   #33
Sorry, we are both almost right. It's to be used on bare wood when you aren't going to be staining, only top coating floors or cabinets with minwax fast drying polyurithane. Not to be used with stain at all.
Of course if you plan on using any product, always read the instructions. Also look both ways before crossing the streets and wear your seatbelts. Please keep medicines out of the reach of children. Friends don't let friends drive drunk. Be kind...rewind. He who smelt it, delt it.
Old 29th August 2008, 08:40 PM   #34
leadbelly's Avatar
Wood & Varnish
Simply, no. Read up on it in some woodworking literature or TV.
Old 29th August 2008, 08:42 PM   #35
strider75 is offline strider75  United States
Does it serve the same function as a the pre-stain wood conditioner?
http://www.minwax.com/products/wood_...onditioner.cfm
Old 29th August 2008, 09:21 PM   #36
leadbelly's Avatar
Wood & Varnish
Yes, it's the same thing.
Old 29th August 2008, 09:28 PM   #37
Sorry, I'm just reading what it says on the label. You can use it however you want, though. It's a free country.
Old 29th August 2008, 09:38 PM   #38
leadbelly's Avatar
Wood & Varnish
No need to apologize, it's obvious Minwax has 2 different formulations for different applications, but they are essentially the same thing. I think I'll look at the price tags next time and buy whichever one's cheaper
Old 30th August 2008, 02:40 PM   #39
moray james is offline moray james  Canada
Default diy varnish like the masters...
http://www.instrumentmaking.keithhil...invarnish.html
moray james
Old 30th August 2008, 07:38 PM   #40
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Sanding sealer "raises" the grain of the wood and facilitates sanding, whether it has been stained or not. It is the first coat of finish.
You are confusing it with so called "wood conditioners". They are not the same as sanding sealer.
Wood & VarnishHide this!Advertise here!
Varnish on old transformer duderduderini Tubes / Valves 12 19th May 2008 01:20 PM
Hot-Rod Varnish Formula John L Full Range 3 12th April 2008 09:03 PM
Recipe for Damar Varnish? bcherry Multi-Way 4 26th August 2005 06:09 PM
