| Construction Tips Construction techniques and tips |
#101 | |
Mostly though, my choice of ply is influenced by some people here who design and build horn type speakers on a professional level. I've no problem taking their advice. |
#102 | |
I hate dead sounding speakers, and would rather error on the too lively side myself.
Tubes and Martin Logan's |
#103 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
veneer stuff. The 2 ply wood on wood veneer is great. A vacuum bag is also very useful for veneering. IMO Shellac is the easiest finish to apply by hand and get a good result.
NBL (No Black Line): FormWood Industries Two-Ply Wood on Wood Veneer Stock List Vacuum Pressing Systems -- Veneer Glue /www.veneersupplies.com/categories/Vacuum__Press__Items/Vacuum__Press__Kits/ Shellac |
#104 | |
Bob |
#105 |
The cabinet should not be made to sound dead, it should be made to sound good to the listener and compliment the driver, crossover, etc. It's a system and has to all work together well.
http://www.fleawatt.blogspot.com |
#106 | |
Once ideas, goals and concepts fade away you are left with reality, and you have to deal with it. Dealing with it includes getting it all to work together as cervelorider talks about. That is just my opinion, my "school of thought". No right or wrong, just have some fun with it.
#107 | |
You talk about a cabinet that sounds "dead". I'm talking about a cabinet that doesn't sound at all. If you are using a dull sounding driver (the Pioneer BOFU comes to mind), a too thin or poorly braced plywood cabinet will sing and add "life" to the speaker. If you are using a Lowther or some of the AN drivers, you sure don't want the cabinet adding any additional brightness. Yes, that synergy thing does work, but proper design makes the task easier. Bob |
#108 |
Other than the sound problems from some kinds of solid wood out there the big problem is the wood warping. you can use birch ply but it does not look as good with the laminated end grain showing. and we all know the problems with the bad looks of MDF. but all and alll the best solid wood for sound, looks and the least amount of warping is white oak !!
| Varnish on old transformer | duderduderini | Tubes / Valves | 12 | 19th May 2008 01:20 PM |
| Hot-Rod Varnish Formula | John L | Full Range | 3 | 12th April 2008 09:03 PM |
| Recipe for Damar Varnish? | bcherry | Multi-Way | 4 | 26th August 2005 06:09 PM |
| Page generated in 0.09834 seconds (78.79% PHP - 21.21% MySQL) with 11 queries |
