10th Annual Vancouver Island diyFEST 2013 - Page 29 - diyAudio
Go Back   Home > Forums > Member Areas > Clubs & Events
Clubs & Events Audio related organizations and events
Old 22nd August 2013, 07:38 PM   #281
Dave R is offline Dave R  United States
Dave R's Avatar
Cal,
I've been looking at the "Now you can" Cornu thread. (made it about 1/3 of the way so far!)
Which drivers did you end up using in your Cornu's?
Ref Post # 244
Originally Posted by Dave R View Post
1. the little cornu that could!
and
3. Cal's larger Cornu
I found some of the Aura 3" / 16 ohm drivers. Did you try that one?
Would a different size or spiral help out different drivers?
- Dave R
the 200% Norske
Old 25th August 2013, 04:49 AM   #282
Speakerholic
Cal Weldon's Avatar
Hi Dave,
Yes, I tried 6 different 3" including the really cheap and the mid priced Aura's. The LG's came in first and the JVC's came second IMHO. My BIL up in Prince Rupert now uses the midpriced Aura's in his. The small speaker is a spiral, not a Cornu shaped spiral.
The large *** kicking bass units are a Cornu style with the Fostex FF125WK and the full complement of planet10 treatments.
I would not make a regular spiral again as I think the bends in the Cornu horn help to damp the higher frequencies.
planet10 needs your help:
Let's help Ruth and Dave
Old 25th August 2013, 05:02 AM   #283
Dave R's Avatar
thanks for the info Cal.
I think I'll make a pair and use them in my shop space. Looks like a fun build, and the output certainly puts a smile on everyone's face. This could be the biggest "Bang for the buck" speaker project ever.
- Dave R
the 200% Norske
Old 25th August 2013, 05:07 AM   #284
Speakerholic
Cal Weldon's Avatar
I think one of the Fostex's that does the high end better might be well suited to this as it really is a bass cabinet when you get to the 27" size.
Yes they are a fun build. The funnest I can remember.
Cheers
Old 26th August 2013, 10:29 PM   #285
Speakerholic
Cal Weldon's Avatar
You know Dave, you might be right. That plus the fact it's one of the lightest speakers of that volume, makes it that much more fun.
Old 27th August 2013, 03:11 PM   #286
howardg is offline howardg  United States
Default Cal with his Cornus at DIY FEST
I thought this pic fun for both threads-I also posted it to the cornu thread. Pretty sure the drivers are the Fostex FF125WK with Planet10 mods
They had a lot of bass considering driver size, they must be really bass-ful on a wall.
I remember wondering if they would benefit from thicker front and rear baffles. I thought that the baffles were vibrating/radiating. If that is the case, the sound would be different with thicker baffles.
I can see how the 3/8"(9.5mm)"underlayment"(that's right, Cal, isn't it?) baffle material would be dense compared to its foam-core precedents.
Old 27th August 2013, 03:33 PM   #287
Default A shot of Cal's foam core cornus at DIYFest
Old 27th August 2013, 03:38 PM   #288
Default TEDDY BEAR PICNIC
Dave D, Dave R and Cal
Old 27th August 2013, 03:44 PM   #289
Default An unusually relaxed Chris
Old 27th August 2013, 03:44 PM   #290
Speakerholic
Cal Weldon's Avatar
To answer Howard, here is the build thread for the Cornu's.
Ever think of building a Cornu Spiral horn? Now you can!
Copyright 1999-2017 diyAudio
