| Clubs & Events Audio related organizations and events |
#221 | |
2) Because the music is not a square, but a bunch of sine's, which it has no problems supplying with great force. The square shows more about rise time, than freq. response. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#222 |
You could give the Zen 7 article a read, to get a general idea of what we have been up to.
http://www.passdiy.com/pdf/zen-v7.pdf Magura
#223 |
Thanks Magura ,
There is less fog now ...............
#224 |
If you got the cash for making such an amp, I sure would recommend giving it a shot.
Lot's of work, compared to the CCS version, but worth every minute/$$$. Magura
#225 |
I'm now starting on a CViller F5 with "mods" .
is there a good/better/best approach with the inductor , as to type , size etc? .......
#226 | |
my Papa is smarter than your Nelson ! tnx to |
#227 |
My inductors are bigger than yours!
And like if that isn't enough, my dad is fatter than your dad ![]() Magura
#228 | |
Best= even bigger air core bifilar inductor. Even better= 2 friends to help you move any of the above ![]() Magura ![]() EDIT: F5 with mods?
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com Last edited by Magura; 1st February 2010 at 06:47 PM. |
#229 | |
5 ,10 , 20 mh
#230 | |
The air core is a lot easier to deal with, regarding saturation, as there is no such thing. For an air core, you can get away with 2 x 80mH. Now that doesn't sound all that scary, but you also need low DCR, which makes it somewhat more problematic. I made mine of 12 gauge copper wire, which gives a DCR of 2R4 per winding, as I recall. What I do recall very clearly, is the weight of them: ~22kg a piece! Magura
| Greetings from Denmark | HenrikW | Introductions | 5 | 28th September 2006 05:57 AM |
| Greatings from Denmark | miju | Introductions | 11 | 19th March 2006 03:04 PM |
| Fostex in Denmark :) | Hoffmeyer | Full Range | 0 | 16th December 2003 02:23 PM |
| SOZ...in denmark :-) | Magura | Introductions | 2 | 28th October 2003 05:33 PM |
| Hello from Denmark - buildt an amp! | Thomas | Introductions | 0 | 6th July 2002 01:09 PM |
| Page generated in 0.11938 seconds (78.97% PHP - 21.03% MySQL) with 11 queries |
