| Clubs & Events Audio related organizations and events |
#421 |
Now these I *really* *really* like. Any info on how to build one?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#422 |
but everyone I've asked about these has never fiound the plans (which are easy enough to find), oh great pooba.
er the MLV looks like an untwisted Ace, if using proper grammar...and yup, chris, that's a phase plug... audio porn to follow. Had a quick listen. not as bad as many suggest about mid 70's speakers.
stew ☮ -"A sane man in an insane world appears insane." |
#423 | ||
think small - close to "classic" Voight pipe - the only clues given by Terry were : Quote:
FF85K Does make one think about adding bass driver below 200 or so, but then the cuteness factor is shot.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#424 | |
I think what Kevin is referring to is the Fostex 108e Sigma's that were played in the Dbl horn on the back deck. Earlier in this thread he had wondered what they were and described them as looking like someone had stepped on them Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#425 | |
Speakerholic
Altec Lansing |
#426 | |
Speakerholic
#427 |
I own a pair and they really do sound good at what they do. I am not home but I will post measurments tomorrow.
#428 | |
not squashed - rather an elaborate stamped cone designed to reduce resonances - a close inspection of the surround and spider will reveal Fostex has more than a few tricks up their sleeve besides just bigger magnets . http://www.fostexinternational.com/d...df/fe108ez.pdf Yup, they did sound quite sweet indeed - FWIW, the best performance I've heard yet from this driver.
#429 | |||
On the board, the "B" and "T" marking on the silk side is just indicating Bottom or Top for the cap orientation. Again, if you intend to use more than 6 caps (3 pairs), be sure to install them in pairs starting with the top pair, then install the bottom pair, then another top pair and so forth. Also, Mouser has a Vishay bridge rectifier for about $4.72 (USD), I'll post a part number for you in a bit, as I don't have it handy. Kevin's pretty busy now through the weekend, but I think he'll have some comments after that. Hope this helps, Best Regards, TerryO
#430 |
Ok, I found the Mouser part number for the bridge rectifier.
It is : 625-GBPC25005-E4 I should let Kevin address this, but I think that he felt that with a Fused IEC socket, you could go to a power switch then another fuse to the Transformer followed by the bridge rectifier (FWIW: this is a large bridge rectifier, install it in a "Dead Bug" configuration). The outputs of the rectifier then go onto the board's supply inputs (V- and V+). The sun is starting to show, so I have to go and nail up some siding on the house. I'll check back later. Best Regards, TerryO
| Page generated in 0.14934 seconds (82.82% PHP - 17.18% MySQL) with 11 queries |
