Clubs & Events Audio related organizations and events
The Burning Amp Festival- an Audio Happening
Old 19th January 2009, 08:49 PM   #1511
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Originally posted by gl
Hi Vladimir,
Thank you for posting more information about your amps. Having seen them and heard them in person I have to say that I have never come across a finer DIY project! I really think that they deserve their own thread over in the PL forum. I fear that all this wonderful info will get buried here and be forgotten.
I have one question for you.
I count 10 output transistors on the one main heatsink you show out on the bench. That means that your amp has 20 output transistors total. But the X600 manual on the Passlabs site states that that amp has 48 output transistors. Can you help me understand the difference?
Graeme
Regarding the output transistors,
You are correct, but essentially this is an AB class amp. With that in mind MOSFETs are not cooking like in the class A amp. The design for X600 and X1000 is the same, with only difference in the power supply voltage and amount of output transistors. X350 is almost the same. As we know in regards to the Mosfet capacitance it is always better to have less MOSFETs in the output. Since I have plenty of heatsinks that gave me a luxury to bump up the current through the smaller amount of MOSFETs. Even with that my sinks are handling cooling really well. My power rails are just a few Volts less than what is in original, so that helps as well. The boards that I use are meant for X600/X1000. This amp is a real monster, and it has endless power. I am using them for my base speakers in three way active system and the bass is - you remember it I hope from BAF2007.
Regarding the thread on this I didn't start it with the reason. Nelson never intended to have this as DIY amps. I happened to stumble upon offering from our reputable member who was selling a few boards here in the market place. He made just a few for his own pleasure and wanted to recover the cost of making them for himself.
I was lucky, but did not want to talk about the circuitry in respect toward the Nelson. That is why I never started the thread. What we are talking here is more about the machining and that is OK. Graeme, thank you very much for the compliments. Coming from you they have the special meaning for me.
Now note to readers:
I will use this chance to answer any possible inquiries sent to my email: No schematic is available from me until and if Nelson makes it public. Please, please, please do not write to me with questions like that - nothing will change my mind. Sorry.
www.burningamp.com
Old 19th January 2009, 10:20 PM   #1512
FastEddy is offline FastEddy  United States
FastEddy's Avatar
" ... Since I have plenty of heatsinks that gave me a luxury to bump up the current through the smaller amount of MOSFETs. Even with that my sinks are handling cooling really well. ..."
I believe that you may find that, unless you really pump up the volume (MOSFETs generally are power passers, rather than just current or voltage gas passers), ... and will run quite within thermal specs at lower listening levels and still provide the headroom you expect. ...
Old 20th January 2009, 02:18 AM   #1513
wrenchone is offline wrenchone  United States
wrenchone's Avatar
AR2 - Thanks for the heads up on DIY powder coating. I may try getting a rig, as spray can wrinkle coating is a bit hit or miss - mostly miss. The powder coat finish is probably more durable in the long run as well.
Old 20th January 2009, 02:28 AM   #1514
FastEddy's Avatar
" .... The powder coat finish is probably more durable in the long run as well. ..."
And it is more environmentally correct (cough, cough) ... and harder to scratch ... and easier to clean up after spray on ... and less flammable and better temperature resistant (to ~ 350 F.) ... and IMOP better looking than a spray can paint job.
Old 20th January 2009, 05:33 AM   #1515
tommak is offline tommak  United States
Default Heat Sink Prices
Originally posted by hayenc
The emails I sent to the site for heatsink quotes get returned as undeliverable. Has anyone else had any success?
I cut and pasted the email address and got a response the next day ( see below ).
The cheaper one is 5.25" long, while the $42 one is 11.75".
Tom
1-19-09
Good afternoon
For your request on the following……
6 pcs G12264
Your cost $ 23.50 each.
We have 34 pcs in our stock, subject to any prior sales
6 pcs G12265, Rev D
Your cost $ 42.00 each
We have 121 pcs in our stock, subject to any prior sales.
When and if order is placed, we will then quote shipping cost.
If you should need anything further, please let me know.
Thank you
Joann List
Customer Service
Darrah Electric Company
5914 Merrill Avenue
Cleveland, Ohio 44102-5699
216.631.9944 Direct Line
216.631.0440 Fax
www.darrahelectric.com
Your Source For: Aavid, ABB, Crydom, Dynex, Enerpro, Iconopower, IXYS, LEM, Powerex, R-Theta Thermal Solutions, and Power Assemblies
Old 20th January 2009, 06:55 AM   #1516
Master Burner
AR2's Avatar
Just came back from Willie Nelson concert at Filmore. Had a good time. I would call it more celebration than concert. The last day! Happy tomorrow morning!
www.burningamp.com
Old 20th January 2009, 06:58 AM   #1517
Master Burner
AR2's Avatar
Default Re: Heat Sink Prices
I hope you agree with me. These prices are steal! Also I remember now, these prices are the same I paid two years ago. You know that they will cut on a appropriate size for you?
www.burningamp.com
Old 20th January 2009, 07:00 AM   #1518
ashok is offline ashok
ashok's Avatar
With all the doom and gloom around us , the next BAF should be a bright spot and hopefully more people will have time to drop by.
Maybe 2 days next time ? Hopefully more people will bring in their DIY equipment for demo.
Should make up a demo CD list so that people can get familiar with the music that will be used for demos. Hearing a familiar recording helps to form one's opinion of the demo equipment.
AM
Old 20th January 2009, 07:06 AM   #1519
Master Burner
AR2's Avatar
It is all true. I find it even much easier to apply than any regular paint. Keep this in mind as well: If you screw up anything before you start baking you could always just blow powder off and start from scratch. What do you think how I know that?
The hardest part is putting the part to the oven while is hanging from the baking rack without touching anything or falling from the hanging hooks. Keep your owen close to where you are spraying. I sifter powder coat any time I fill the bottle. Buy enough powder because it goes fast.
www.burningamp.com
Old 20th January 2009, 07:27 AM   #1520
wrenchone's Avatar
There are some fascinating and lurid possibilities for powder coat colors, especially if you check out the folks who cater to the custom automotive crowd. There are also several rigs available on E-pay for under $100, including some blower types and some needing a small boost of compressed air.
The Burning Amp Festival- an Audio HappeningHide this!Advertise here!
