Go Back   Home > Forums > Amplifiers > Class D
Old 10th April 2007, 01:24 PM   #1
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Default Active Elevated Rail Hi side Bootstrapping Technique for IR2110
Hi Folks,
I have successfully implemented this elevated rail bootstraping technique to prevent failure mode in IR2110 gate driver during low frequency heavy clipping conditions...
Your comments please....
Kanwar
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 10th April 2007, 01:35 PM   #2
R U sure you have drawn it right ?
One possible solution can be found on IR's website (some charge pump using a 555).
Another one would be the use of a simple current-source from your elevated rail. You wouldn't need much current supplied by this (in the range of 350 uA IIRC).
Charles
Old 10th April 2007, 01:41 PM   #3
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Can't you just use the positive rail, an emitter follower, and a larger capacitance?
Brian
Old 10th April 2007, 01:41 PM   #4
Workhorse's Avatar
Mine isnot a current source, its a voltage source type of 15V floating and is referenced to the source....I have tested the amp with DC at input also and the output easily delivers it without any damage in continuous load....
Old 10th April 2007, 01:45 PM   #5
Workhorse's Avatar
Originally posted by BWRX
Can't you just use the positive rail instead of the "elevated" rail?
When you want to drive low frequency signals, the charge in bootstrap caps decays and the Mosfet enters linear conduction mode and would get damage,but using this elevated rail of VCC+15V the cap always remains charged, even if DC signal is used at the input of amp[provided DC coupling]...
Old 10th April 2007, 01:47 PM   #6
I realized that after I posted, and edited my previous post
Your scheme makes sense but if you don't plan on amplifying DC wouldn't it be easier to just increase the value of the bootstrap cap?
Brian
Old 10th April 2007, 01:49 PM   #7
Workhorse's Avatar
With this technique the amp can act as continuous DC voltage source....
Old 10th April 2007, 01:51 PM   #8
The base voltage must be higher than the emitter voltage to turn on the transistor. So I think you have drawn the circuit differently than you actually implemented.
This wouldn't help since it wouldn't allow sustained turn-on of the upper MOSFET which is what is intended here. The idea is to allow driving the amp heavily into clipping without causing latchup or worse.
Not that heavy clipping should be a usual mode of operation of any amp - but it is always good practice to design things such that they survive any type of misuse.
Charles
Old 10th April 2007, 01:51 PM   #9
Workhorse's Avatar
0-100% duty cycle could be realized,no smoking of amp during continuous clipping of low frequency signals at output....
Old 10th April 2007, 01:55 PM   #10
Workhorse's Avatar
Charles
Yes,
Actually
The elevated Rail voltage is 25V
The Zener voltage is 16V and thus the floating bootstrapping voltage is around 15V[including losses]....perfect to drive the mosfet during heavy clipping
Single rail, active I/V for TDA1543, TDA1545A rbroer Digital Line Level 69 26th August 2009 11:25 AM
ac side active PFC basreflex Power Supplies 1 7th January 2009 06:58 PM
how ir2110 drives the high side mosfet in h bridge gowri Class D 2 10th April 2008 06:30 AM
DC heater (+/-) -> elevated? Cobra2 Tubes / Valves 3 29th March 2008 02:39 PM
ir2110 and 6 x irf640 per side? jake83 Class D 8 4th March 2007 01:08 PM
Page generated in 0.12699 seconds (74.36% PHP - 25.64% MySQL) with 11 queries
