Who ever seen this CLASS-D amplifier - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th April 2007, 03:50 AM   #1
Send a message via MSN to ANALOG GUY
Default Who ever seen this CLASS-D amplifier
My friend send me his pictures about 2400w CLASS-D, He told me that him bought it from CHINA.
But in CHINA he contact only dealer, Please Chinese member who known this model please suggest me for order and let me know its website.
Regard
Analog guy
Old 8th April 2007, 03:52 AM   #2
Question CLASS-D from China or Taiwan ?
Pics 2
Old 10th April 2007, 01:21 PM   #3
Smile Who ever seen this CLASS-D amplifier
i think it CLASS-TD but i don't know made in ...
search www.lab.grupen
Old 10th April 2007, 05:28 PM   #4
audiosteve's Avatar
I'm not sure if that is a LabGruppen amp or not. In any case, the URL to check would be http://www.labgruppen.com
two p's in gruppen
Nihilism is best done by professionals.
Old 17th April 2007, 05:36 AM   #5
PowerSoft is well known for 1RU class D amps, although it doesn't look like any PowerSoft I've seen.
Old 6th May 2007, 03:09 AM   #6
Talking Who ever seen this CLASS-D amplifier
i see it in thailand!
checking www.tafnaudio.com
Old 7th October 2007, 05:33 AM   #7
Default This amplifier is made in Thailand
This amplifier is manufactured in Thailand, designed by my self and the R & D team from the firm TAFN ENGINEERING CO.,LTD
D-TECH 2400 is a highly reliable advanced CLASS-D power amplifier capable of delivering high power over the whole audio band without overheating in a very small size. At the same time it is capable of reproducing sound with outstanding clarity and stability like never before possible with conventional amplifiers.
So far for what i hear, no other PA amplifier of this size and weight can match the power and sound quality.
Many PUBs and Discotheques in Thailand are changing ther systems from reliable class AB amplifiers for this new Class-D model ( D-TECH 2400 ).
Old 7th October 2007, 06:48 AM   #8
MOER is offline MOER  United States
Default Class D amplifier
I find it interesting that the switchmode supply can only work from 140v to 260v AC.
So in countries that have 100-120v AC mains this amplifier is useless.
Also by the way there are no such things as "watts RMS". It is a non existant term.
Watts are calculated by measuring the volts rms multiplied by the current rms, and therfore RMS X RMS cannot = RMS.
The fact that the square root of 4 x the square root of 4 does NOT equal the square root of 4 but is just 4. There is no root mean square attached the answer of 4.
I would be interested to know how you measure the damping factor )not dumping factor) at 800 and you do not even specigy the load impedance. Damping factor is simply defined as the load impedance divided by the output impedance of the amplifier.
So assuming that 8 ohms was the impedance to which the DF was referred to this means that the output impedance is 10 milli ohms. The output coil will contribute more than this.
Old 7th October 2007, 02:44 PM   #9
Not quite.
You are missing the load resistance in your calculation. The power is normally calculated as:
Vrms ^2 / Zload.
So the term Watts RMS is good.
www.newclassd.com
Old 7th October 2007, 05:04 PM   #10
Default Supply voltage
This amplifier IS NOT DESIGNED FOR 110V. countries. Is designed to be used in Thailand wich is 220V. and can take voltage fluctuations in that 220V countries. Not in the US.
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 11:25 PM
Class A Amplifier Jean-Paul_2 Solid State 22 21st June 2009 03:36 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
Copyright 1999-2017 diyAudio
