| Class D Switching Power Amplifiers and Power D/A conversion |
Hello all,
I am putting together a system in which I would like to use a T amp to power horn loaded Fostex FE166E's from around 400 HZ up. I have modded the T amp as per Panomaniac's directions and am wondering if it is possible to change the value of the input capacitor to cause the amp to act as a high pass filter? Thanks M Vaughn |
#2 |
Yes it is!
For 400 Hz and up, try a 0.06uF cap. That will give you a -3dB point of about 110Hz. That sould block some bass but not hurt you mids. You could try an octave higher, about 220Hz, which would be a 0.033 (33nF) cap. As long as it doesn't change your crossover slope too much, you should be OK.
Take the Speaker Voltage Test! |
#3 |
Thank you kind sir!
I am building a "simple" two way with Focal 13V's in transmission line cabinets handling the bass and the aforementioned t-amp driving the Fostex drivers. I hope to have it up and running within the next week and will post pictures. Thanks again, M Vaughn |
| Using less bandwidth and others | DragonMaster | Everything Else | 3 | 13th November 2004 06:23 PM |
| V/I Limiting | richie00boy | Solid State | 17 | 29th August 2004 03:25 AM |
| limiting the HF in GC | GregGC | Chip Amps | 0 | 6th January 2004 09:18 PM |
| Bandwidth limiting the lm3886 | Flemming J P | Chip Amps | 3 | 2nd January 2004 10:32 PM |
| Page generated in 0.07010 seconds (72.12% PHP - 27.88% MySQL) with 10 queries |
