Go Back   Home > Forums > Amplifiers > Class D
Old 26th March 2007, 07:25 AM   #21
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Hi alexclaire
Near end with designing
Click the image to open in full size.Click the image to open in full size.
Any comments?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 26th March 2007, 11:37 AM   #22
Send a message via MSN to lindomar
Hi LUKA.
Is new version of ARES Proteus 7.1?
Old 26th March 2007, 02:01 PM   #23
luka's Avatar
Hi
It is Ultiboard from National Instruments
I FEEL SLOVENIA
Old 30th March 2007, 06:19 AM   #24
Hi everyone,
gonna make changes with D AMP output stage but need some information about antiparralel free wheeling diode...
Gonna put schottky common cathode in serie with mosfet drain (diode is STPS3045CW) in order to prevent current from flowing through the fet body diode (too slow) and force it to go through the outside diode (antiparrallel).
I'm wondering which recovery time I should use (depends on deadtime i guess) trr=40ns is good ? or do i need less (25-28 ns) ?
With 24ns deadtime (RCD circuit before IR 2113 Low and high inputs R=47ohms C=470pF) when I try to increase output signal to reach saturation output stage burns before saturation...
Should i lower dead time as output stage didn't burn with low deadtimes ?
I guess body diode remains reverse conductive as the other fet is turned on...
someone got an idea ?
Old 30th March 2007, 06:34 AM   #25
What is your switching slew rate ? Be careful not to turn the "inactive" FET on via the reverse capacitance when trying to switch too fast.
Charles
Old 30th March 2007, 08:44 AM   #26
luka's Avatar
Hi alexclaire
But changes to output aren't really necessary, right? It works even without antiparralel free wheeling diode..., fets are just heating more, right?
I FEEL SLOVENIA
Old 30th March 2007, 03:07 PM   #27
Workhorse's Avatar
Hi Charles,
Can we replace the series Schottky's with this....
The centre node is a combination of 2 series nH inductors which ADD a little oFFset to body diode of mosfet, thus enabling the Fast recovery diodes to perform efficiently...
Kanwar
Old 30th March 2007, 03:43 PM   #28
Hi Kanwar
This wouldn't prevent the turn-on of the body diode. But it might help a little to reduce the reverse recovery current peak. But my gut-feeling tells me that I don't like it somehow.
Charles
Old 30th March 2007, 03:51 PM   #29
Workhorse's Avatar
So there's no replacemant for robust schottkys ....
Any another Idea in your mind...
Old 3rd April 2007, 12:26 PM   #30
Bender.ru's Avatar
Hi all. Here is my light version of Fredos Damp.
Back to Back transformers and safety ground dsavitsk Tubes / Valves 1 9th February 2009 10:10 PM
back to back coupling capacitors reddog Solid State 5 3rd January 2006 06:59 AM
Back to Back transformers to get +B of 200V ?? Shoog Tubes / Valves 5 23rd September 2005 03:58 AM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 05:34 AM
Back to Back Polarized Electro's EchoWars Solid State 11 15th November 2003 09:30 PM
Copyright ©1999-2013 diyAudio
