Go Back   Home > Forums > Amplifiers > Class D
Old 20th March 2007, 09:52 PM   #1
bcrazy is offline bcrazy  Norway
Default input connection and ground on ucd 180
I am in the process of putting together my first amp.
How should i connect power ground and signal ground?
I planned on not connection power ground to chassis, is there any reason not to?
I use unbalanced rca inputs. What/where should i connect neg input and ground on the ucd modules?
Can i leave the ground pin on the ucd unconnected???
Should i keep the power ground (O volt) from the rectifers floating or do i need to connect it to chassis?
I use a 2x33V trafo with no 0 Volt line and 2 bridge rectifiers.
Advice needed.
some pictures:
Old 20th March 2007, 09:54 PM   #2
just need to show off this great tool
Old 21st March 2007, 04:23 PM   #3
Use double insulation transfo and parts and distances. Neg input and ground to the chassis. Floating PS, floating AC ground.
http://www.diyaudio.com/forums/showt...ht=#post767515
http://www.diyaudio.com/forums/showt...ht=#post736222
http://www.diyaudio.com/forums/showt...ht=#post673418
You can do a search for putzeys (partial name) and RCA.
Alternative is to use the standard grounded box, but I don't have links to offer for that.
Guy
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
power supply choke with a connection for AC ground? jarthel Tubes / Valves 4 16th March 2007 10:10 PM
Best ground connection mastermosfet Solid State 3 24th February 2007 04:21 AM
Beginner Ground Connection Question TGRANT Analog Line Level 8 17th September 2006 03:46 AM
Acoustat AC ground wire connection noelm Planars & Exotics 7 21st June 2005 08:44 PM
Page generated in 0.08313 seconds (75.31% PHP - 24.69% MySQL) with 11 queries
