| Class D Switching Power Amplifiers and Power D/A conversion |
My voltage regulators on my amp (audiobahn a18001dt) amp are messed. my question is what should I check?
#2 |
diyAudio Moderator Emeritus
What part(s) are they?
Brian |
#3 |
if you mean part number
KIA7915PI KIA7815A |
#4 |
The 7915 is a negative voltage regulator (the 15 in the number means -15V output) and the 7815 is a positive voltage regulator (the 15 in the name means 15V output).
A google search for the specific part won't help much, but a search for the part datasheets from a reputable manufacturer will help you better understand how they're used. http://www.national.com/pf/LM/LM78M05.html http://www.national.com/pf/LM/LM7905.html
Brian |
#5 |
According to your picture you have no Power Supply transistors on the board. Without them you will get no voltage to the regulators.
Why do you think they are bad? The only problem I have ever seen with them in this amp are broken legs.
If it ain't broke Don't fix it |
#6 |
Ok after I put the new Mosfets in I will Remeasure them. Im not all that familiar with a class d amp.
| voltage regulator | Sebastiaan | Power Supplies | 2 | 12th June 2005 07:51 PM |
| Voltage Regulator ! | jleaman | Power Supplies | 11 | 13th May 2005 12:00 AM |
| Voltage Regulator | zoro72 | Everything Else | 0 | 26th April 2004 05:30 PM |
| Voltage regulator help! | kasra | Solid State | 7 | 23rd November 2002 02:07 PM |
| What voltage regulator to use? | Thomas | Everything Else | 2 | 28th September 2001 02:53 PM |
| Page generated in 0.08195 seconds (72.63% PHP - 27.37% MySQL) with 11 queries |
